Michelin TB15 on SC/Carrera body
Hi everyone,
I want to try some Michelin TB15 on my SC. I switched from 16“ Fuchs to 7“ & 8“x 15“ Fuchs. I saw a couple of SC bodied cars with TB‘s in 18/60-15 on the front and 23/62-15 on the rear. On the pictures below it looks quite tight on the rear, so I wonder if some of you guys have experience with the setup mentioned above?
The grey car runs the TB‘s on 7“& 8“ while the red/orange car has 7“& 9“.
Thank you
Marc
Old 02-17-2020, 01:16 PM
Bill Verburg's Avatar
Originally Posted by Villeneuve27 View Post
Hi everybody,
Thank you
Marc
Both front and rear are near maxed especially so in back, The relatively short tire height alleviates that to a large extent, but it's still likely that extra camber is run and probably lip work as well
the rears call for a minimum wheel width of 8.5" running them on 8s will impose a squishy/sloppy quality to the ride, fronts ideally want a 7.7 and the rears ideally want a 10.5
Bill Verburg
Old 02-17-2020, 01:31 PM
