Euromeister wheel, center caps and wheel nuts
Can anyone confirm that my stock 16" Fuchs center caps and wheel nuts will work with upgraded 17' Euromeister wheels?
Also, can anyone recommend what tire size for standard (non lowered) suspension? It seems everyone is running completely different sizes. Thanks
ELUSIVE Fan of all things German, especially Porsche, Audi, and VW. Last edited by ELUSIVE; 02-26-2020 at 05:48 PM.. |
Tires will depend on the wheel specs; width, ET, diameter
Caveman Hammer Mechanic
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Wheels are 17x7 ET 23.3 and 17x9 ET 15.
Stock ride height and suspension
ELUSIVE Fan of all things German, especially Porsche, Audi, and VW. |
I have euromeister wheels 17..used the original centers and lugs...tires would be up to you for looks..I have the same sizes and the 9's are very close to my oil line in the fender..
most efficient and best acceleration, 215/45 & 245/40 x17 w/ a bigger than stock motor, 225/45 & 255/40
1986 Meteor Grey Carrera - We'll meet again in Valhalla. |
Been here a while
I'm pretty sure your 16" tires will not fit the 17" euromeisters.
Lug nuts and center caps, yes....I had to very gently file a bevel around the opening for the center caps, just the smallest amount, probably just the powdercoat/finish was just a bit too thick for the center caps to fit...
looking for 1972 911t motor XR584, S/N 6121622 |
Do you think that duck tape or super glue would assist in getting the 16" tires work on these 17" wheels? Thanks for the insight on the caps.
This is perfect. Thank you!!!
For what it's worth - I went with the 215/45 & 245/40 x 17 that Bill recommends. Great fit! Here's a picture with them on. (and yes the caps & lug nuts fit no problem).
That looks fantastic. Thanks PFNog!
Did you use any spacers with your set up? I have a targa similar to yours with the Euromeister 17", same tire sizes too and I'm thinking about getting some spacers in the back to push it out just a tad more for looks. Still need to get mine lowered.
No spacers. Just lowered a little bit.
(man/dude)
Another data point: 205/45-17 on 7's ans 255/40-17's on 9's. These tire sizes are IMO the best fit for these wheels on this car (a cruiser).
![]() The autoX car has 225's on 8" (widened from 7) on front and 255 on 9's in the rear.
Heavy Metal! Part Deux - The Carbon Copy Project Heavy Metal https://tinyurl.com/57zwayzw (SOLD) 85 Coupe - The Rot Rod! AX beater Quality Carbon Fiber Parts for Classic 911s: instagram.com/jonny_rotten_911 |
![]() 255 on 9's , 205 on 7's |
(man/dude)
That's a sharp looking car! Have raised spindles?
No raised spindles..just lowered..shop said it is not quite euro height..
