Difference in gear shift mechanism
Hi All, I'm currently restoring a -71T. It was all in boxes when I bought it, some of the parts were not accurate.
I got a correct -71 5-speed with the deal. Is there any difference between the 4-speed and 5-speed gearshift lever and attached hardware? I'm thinking since the gear shift pattern is different. If this is the case, please let me know how I identify the lever I have. Thanks in advance, Jörgen Forssling Gothenburg SWEDEN Last edited by Forssling; 02-19-2020 at 03:52 AM.. |
Anyone? Please!
//Jörgen |
post some pictures what do you have so we can actually see it
Ivan
1985 911 with original 502 191 miles...808 198 km "The difference between genius and stupidity is that, genius has its limits". Albert Einstein. |
It's buried in boxes of parts. I'll dig it out this weekend.
Thanks, Jörgen |
yup, that would help for setting it up for you
Ivan
Here's photos of my setup.
Thanks for your help Jörgen |
Looks correct for a 71.
Ok. So it is for 5-speed or 4-speed or both?
//Jörgen |
That looks like the one year only 1972 shifter for a 915 transmission I recently listed on Pelican. That little cam held in place with the roll pins and the two small springs are not in the two 901 shifters that I have. Here in the shop
1969 911TR lightweight, 1850 lb. 245 HP 2.7 short stroke 1973 1/2 911T S optioned sunroof coupe (in progress) 1998 993 Carrera Cabriolet PSS10 lowered E88 cup wheels 1999 996 Carrera Cabriolet |
My '71 T has the heater controls back by the parking brake, that shift mechanism looks like it has the slot for it near the front if I'm not mistaken? However my car also has a later transmission that was put in by the previous owner so maybe I'm wrong on this
1971 911T British Racing Green 3.2L 2013 981 Boxster S Aqua Blue/Grey 2014 981 Cayman S Agate Grey/Black enjoyed and passed along: 1990 964 C2, 2007 C4S Cabriolet, 1997 986, 1958 356 A |
Under the radar
According to the parts diagram/ parts numbers I have, the only difference between the 4 and 5 speed is the knob.
Here is a shot of my original '71 shifter. The slot for the heater is still there, but not used on my '71.
Appreciate all your help! //Jörgen |
Under the radar
Now that I look at your shot in post #2 and #7, it does look like you might have the one year only '72 shifter.
Here is a shot of mine so you can see the difference. I will also post the breakdown I have. ![]() ![]()
Gordon ___________________________________ '71 911 Coupe 3,0L outlawed #56 PCA Redwood Region, GGR, NASA, Speed SF Trackrash's Garage :: My Garage Last edited by Trackrash; 02-21-2020 at 04:36 PM.. |
Thanks Gordon.
It certainly is a -72 shifter I've got. Since they have all different shift patterns I have to get another one or at least get another stop plate. (14) in my second post. Is the pin marked with an arrow riveted or welded in place? I've got the hole for it in my main bracket and I figure it might be an easier fix than locating a new shifter here i Sweden. //Jörgen
Hi Again, I have a pin on the other side similar to the one with the arrow above. I used a drift to get it out. If it's long enough maybe I can use it.
Would you be able to measure how far it protrudes on the other side? I also ordered a new stop plate. If anyone has use for the -72 parts, let me know. //Jörgen |
Other than the preference to use the correct MY parts, I would suggest considering replacing it with a 73-86 shifter. Bolts in, doesn’t care if 4 or 5 speed, more precise (relatively speaking).
911 shifters are just levers. Detents are in the gearbox. Sherwood |
//Jörgen |
Under the radar
OK, here is a shot of mine showing the pin. It appears to be spot welded.
After looking closely at the picture of your shifter, it does indeed look to be a '72. Too bad you are on the other side of the world as I would be willing to sell my unused shifter.
Yes I'm on the other side of the pond... But isn't it nice to get help from all over the world!
What I would need from you Gordon, if you could be so kind, is if you could measure the length of the pin protruding on the backside. I enjoy my restoration and these "bumps on the road". Since I've bought my car in parts and not complete I have some work to do... It's not the first time I found out that I got the wrong parts for my car. Thanks a bunch from a cold and rainy Gothenburg Sweden! //Jörgen
