Born to Lose, Live to Win
ramonesfreak's Avatar
Front seat install frustration
Had my front seats redone and installed them this morning...after finally getting them bolted in, and while doing so, I noticed that neither seat slides forward and back as easy as they did.
So I took them out, removed rails and degreased and cleaned and relubed them and looked them over carefully to understanding how the work and reinstalled.
Still very stiff to slide forward and back....not a huge deal but....you know how it goes..it’s different after messing with it so I’m like
I’m guessing that I did not replace each rail in the exact spot from where they came and with almost 40 years of use they broke-in in a particular way and now I’m feeling resistance that wasn’t there before?
Or is there some adjustment trick I wasn’t aware of?
Things fall apart; the center cannot hold…
1983 911sc
2025 Chevy Colorado ZR2
Old 02-22-2020, 06:27 AM
Analog Air Cooled
Hotshot's Avatar
Did you notice any shims? Some have the slightest little bit added to where they were. Could also be flexing a little bit. 40 years under the same load and then removed for a while and re installed. Might need new bum wiggling and messing about.
86 Targa
91 964
13 6 SPD Cayenne
Old 02-22-2020, 06:32 AM
I'm good with tools.
AG81's Avatar
I experienced the same after redoing my seats. I removed and checked everything. I assumed they just need some back and forth action over time...... They have improved and it has taken a while. Mine is a weekend car and I tend to get it positioned for me and not move the seat that often.
72 911 Coupe "OILDOOR"
24 INEOS Grenadier (daily)
13 991.1 Coupe 2S 3.8L (currently undergoing mods)
02 996 4S
Old 02-22-2020, 07:01 AM
Thanks guys. Didn’t see shims
When I cleaned them I did notice that the ball bearings in the sliders wore deep grooves. So I’m guessing the bearings aren’t riding in the same grooves
Old 02-22-2020, 07:15 AM
Ah, the art of letting sleeping dog …
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 02-22-2020, 11:54 PM
Bill Douglas's Avatar
I'm thinking with a bit of luck they may wear into their new location and be just fine.
How do the seats look after their refurbish job?
Old 02-23-2020, 10:46 AM
Like new. My guy used leather covers from gahh. Nice quality
1983 911sc
Old 02-23-2020, 12:23 PM
I have had some improvement by loosing the mounting bolts so the tracks have some movement. Then butt in seat, exercise the forward to aft adjustment and tighten. Sometimes twisting Left or right and tighten also works. Rob
Old 02-23-2020, 01:22 PM
Second this. Loosen everything up a bit and run it back and forth a bunch and re-tighten. I swapped my seats L/R->R/L and experienced the same as you until I did this.
Current:
1984 911 Targa Whale Tail "Gemma"
2014 Boxster S (wife) "Sir Jenson" (She named it...not me)
Previous GF's - 986 Boxster S, 987 B Cayman, 981 B Cayman, 981 GT4
Old 02-23-2020, 03:21 PM
Rescuer of old cars
Arne2's Avatar
I have had to shim the sliders to the seats. Bolt the sliders to the seat, then set it on a flat floor and see if both sliders are flat on the floor. If not, shim one until the sliders both at flat on the floor on the same plane. Made a huge difference in my '84 with sport seats.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 02-23-2020, 04:27 PM
RFP RFP is offline
RFP's Avatar
Originally Posted by ramonesfreak View Post
< snip >
I'm thinking this is probably your problem. It's easy to get one side or the other wrong.
Maverick Region PCA, Fort Worth/Dallas area
1987 911 Coupe, Black M491 3.4 // Turbo-Look Registry # 1249
1977 911 Coupe, Metallic Sienna (I think!)/Lobster SOLD
1982 924 White, SOLD long ago
1966 912 Red, SOLD, totaled a week later by its new owner
Old 02-24-2020, 02:40 AM
cycling has-been
bkreigsr's Avatar
If these seats are in your '83, they are single lockers, and are two separate rails, correct?
Be certain that the rails are exactly parallel when you tighten them - there is really a lot of slop/play in the mounting holes.
Bill K
Old 02-24-2020, 10:51 AM
Flojo's Avatar
yep.
install in position, %80 torque
sit in seat, slide forth and back
now torque down to spec.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 02-25-2020, 03:33 AM
