Rear view Mirror removal
I replaced my aging rear view mirror about 10 years ago with an aftermarket one. Like the original, the mount is glued to my windshield. Unfortunately, I didn't locate it properly. After replacing my visors, I need to relocate the mirror. Has anyone found a safe way to remove glued mount or a solvent that works to soften glue?
Old 02-18-2020, 08:30 PM
Good luck with that.
Mirrors will fall off after 30+ years on their own at an inopportune time. One of the guys in our PCA region it 6'4" and he just glued on a new mount to get the mirror up higher to make it better for him to use the mirror. The old mount is still in place, and no one noticed unless it is pointed out.
The only thing that might work is a heat gun. Most of the time trying to remove that mount breaks the windshield.
Old 02-19-2020, 10:12 AM
That's what I was worried about!
Old 02-19-2020, 11:10 AM
Designer King
Paulporsche's Avatar
Do you remember who supplied the mirror? Did you use their glue or something else?
Can you contact the mirror supplier/manufacturer or the glue manufacturer and ask them?
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 02-19-2020, 12:39 PM
RETIRED
Joe Bob's Avatar
Try dental floss,,,,,
Or
https://www.youtube.com/watch?v=Ij24aT_3oSY
2012 ML350 3.0 Turbo Diesel
Old 02-19-2020, 03:55 PM
LOL - at ~57 seconds, you can see/hear the windscreen develop a new crack, just before he says "but it won't hurt the glass"...
'77 S with '78 930 power and a few other things.
Old 02-23-2020, 09:42 AM
skinnerd's Avatar
I've used a skinny guitar string with good results.
Just wear a pair of thick leather gloves and saw with the guitar string.
The mirrors should be put on with an adhesive patch...not a glue.
"Are you out of your Vulcan mind?"
Doug
2022 Carrera 4S, 1989 Delta Integrale, 1973 911T CIS
Old 02-23-2020, 07:57 PM
