Front torsion bar missing dust cover?
I noticed that the passenger side front torsion bar is missing the dust cover on the front of the A-arm.
Driver side:
Passenger side:
Is the only part missing part number 900-040-008-01-OEM ?
https://www.pelicanparts.com/More_Info/90004000801.htm?pn=900-040-008-01-OEM
Since it's missing the cover, I'll wipe it out and try to smear some grease in there. What is the proper grease?
Old 07-01-2020, 02:28 PM
Porsche Addict
The cover is somewhat like a freeze plug. You should be able to get it in there.
Lawrence - 1986 911 Carrera Coupe Grand Prix White
1959 Land Rover Series II
1962 Volkswagen Sedan Ragtop
1959 Porsche 356A Coupe
1971 Porsche 911T coupe
Old 07-01-2020, 03:08 PM
Lash
Bentley's manual calls for MoS 2 lube.
I used Super Lube synthetic which has PTFE. Any good quality grease with PTFE will do the job.
Most important to remove contaminated grease and than install dust cap.
Lash
Old 07-01-2020, 03:14 PM
KTL KTL is online now
Schleprock
KTL's Avatar
Yes you definitely need to install the plug/cap. It keeps dirt, and more importantly water, out of the splines. Be sure to "stake" it in place after you tap it on there. Stake it with a couple of dimples via a center punch and then paint it to seal the edges.
Kevin L
'86 Carrera "Larry"
Old 07-01-2020, 03:24 PM
Thanks. I have Super Lube on hand.
I'll wipe the grime out the best I can without disassembling everything and smear new grease in the best I can. Fortunately, while it's dirty there is no sign of corrosion on the exposed splines.
Old 07-01-2020, 03:32 PM
