Question re: Replacing Rear View Mirror in '84 Carrera
Hey Pelicans:
Hoping this will be an easy one. If I would like to replace the rear view mirror in my 84 Carrera, can I just replace the mirror portion of the setup or will I need a new base as well? Thanks in advance! |
I replaced mine several years ago Myami.
It slips in and out of a half-round shoe. Be careful to source the correct mirror for the existing base......that base is glued to the point that I couldn't remove it without risking the windshield itself. It's easy, just don't pry or force anything. Our old windshields can be brittle. |
Let me go take a look, it's been a long time.....standby
My '84 mirror
Here you go, slides straight up towards the headliner.....again, be careful not to put any angular pressure on the glass.
http://forums.pelicanparts.com/uploa...1582925782.jpg |
If it sticks, and it may since its been there a long time. Maybe a bit of WD-40 and tap it gently. It'll come off.
| All times are GMT -8. The time now is 07:03 PM. |
