1975 Manual seats recline as I drive the car???
So the seats in my '75 are full manual. They also slowly recline as I drive. I have not tried to take them apart to see if there is something I could tighten to prevent this from happening. I searched around but nothing came up. Does anyone have any thoughts on what to tighten up?
They seem to work perfectly fine in other aspects.
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 03-23-2020, 12:06 PM
Hope you find a solution as mine do it as well
Old 03-23-2020, 12:23 PM
Wow no one knows how to take apart or repair 911 manual wheels that have a sagging recline function. Cannot believe this stumped the experts!
Old 03-24-2020, 11:33 AM
Been quite a few years since I had a seat apart, but if you pop out the large covering disc in the adjustment handle the whole mechanism is right there. There is large tin wedge nut, maybe that came loose. Can't remember if there is an actual threaded nut to tighten behind it.
Old 03-24-2020, 12:08 PM
I always assumed it was a Recaro design issue.
My 70 Bronco and the 96 Saleen with LX models, and both Porsches the seats slowly creep back.
About once every 500/1,000 miles or so I end up cranking the knob a turn or two.
Derrick
Old 03-24-2020, 12:50 PM
Designer King
Paulporsche's Avatar
If you pry off the center cap with a small pick or screwdriver inserted into the indents on the outer ring (knob), you can then remove the knob by holding it while pushing aside the inner steel retaining ring with a screwdriver. I think it goes counterclockwise but it it should be apparent which way to go.
Once you remove the housing you will see how these things work. There are 2 fingers that mesh together to hold the back in place. They may be worn, or you may find you can otherwise tighten the whole mechanism up.. Mine worked fine when I redid my seats so I didn't mess with it.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 03-24-2020, 03:28 PM
You going to take yours apart, work through all the pitfalls then let me know how to do it correctly?
Old 03-25-2020, 06:34 PM
