Stupid Question Regarding Fan Belt Swap w/ Factory Toolkit on a 71
Ok, maybe I'm missing something...
The fan is a 24mm nut. The fan is held with the special tool (2 pins for his model). The factory tool kit doesn't have a 24mm wrench. But it has a fan belt. So help me out. How was one (or not?) expected to change the belt on these with the factory tools? Not that it matters, have a tool kit with an extendable 1/2" ratchet at 19mm, 24mm sockets... |
every factory tool kit had the 22mm or 24mm wrench for the alternator nut..what is your other question?
Ivan |
I must be missing something here... |
You have a later alternator on your car. Probably with the internal regulator as well. You will need to do what I did and buy a 24 mm wrench. I have the same situation on my 1973
Thanks |
| All times are GMT -8. The time now is 10:02 AM. |
