Clubsport wheel questions thread
Likely 930 purchase means I'd like to nail down details on swapping out the stock steering wheel.
I'm interested in the clubsport but have a few questions: 1. Is there any source for a new clubsport wheel where the bottom spoke has no seam? 2. Inset/sunken emblem: I see some wheels where the Porsche emblem is in the center, but I'd like to have it sunken flush. Has anyone done this before? I have a large press but I'm thinking that might tear the leather, so thinking I could recover it, and press the sunken shape in before the leather is attached? 3. Are there different choices / options on how I'd mount a clubsport wheel to a 930? Thanks in advance. |
Bump .... as also interested in brains trust responses
1. I believe all the new ones have the seam on the bottom spoke. I'm guessing if that is what you want, you will need to get a used or possibly NOS wheel.
2. Not really sure you can do that. The older horn pad was made of metal, so that may be possible. The later horn pads, might be plastic. I can't remember, but have to check my other wheels. 3. To mount it to your Porsche, you have 2 choice: get a 3 bolt Atiwe/Formel hub, or get an adapter.
The fun - '06 Carrera, '79 930, '06 S4 Avant, '16 i8 The mundane - '24 Tesla Model 3, '22 Tesla Model Y, '19 Tacoma |
a.k.a. G-man
I thought all OEM 930S wheels had a seam at the bottom spoke.
Aftermarket wheels do not.
Сидеть, ложь, Переворачиваться |
the lower spoke seam. The seam is there because the Club Sport wheel uses the best (i.e. most expensive) Atiwe wheel and that wheel uses a one piece leather cover and that makes a center seam necessary. The cheaper Atiwe 930S lookalikes cover the spokes with "glue on" individual pieces of leather. Those wheels are genuine Atiwe wheels just cheaper versions. If you look at a "no seam" wheel closely you will see where the glued on spoke pieces meet the main cover. Also, the "real" 930S has the Porsche original parts "triangle" stamped into the frame. The horn button is also different in that it has no metal Porsche crest on it, but instead has the crest embossed into the leather. Check this old for sale thread. It shows what a genuine Club Sport 930S looks like. Note the one piece cover (no glue on leather on the spokes) and the embossed Porsche crest. 930s steering wheel/hub new $475 EDIT: Check out this for sale thread for a "lookalike" 930S wheel and you will see the stark difference between the genuine wheel above and the one shown here. FS: 930 Steering Wheel Typ Atwie
'80SC Widebody 3.6 transplant Anthracite "The Rocket" Long gone but still miss them all: '77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!) '71 911T Coupe White, '70 911T Coupe Blue '68 911 Coupe Orange, '68 911L Soft Window Targa Last edited by uwanna; 03-09-2020 at 12:48 PM.. |
A related question, looking at the hub for sale by our host:
https://www.pelicanparts.com/More_Info/1004981619X1.htm?pn=100-498-161-9X1&bt=Y&fs=0&SVSVSI=911M It says: "Note: Does not include Signal Cancel Pin." Do you reuse the signal cancel pin from the existing wheel assembly, or is this a separate part that needs to be purchased? |
a.k.a. G-man
Don,
Cancel rings are generally easy to remove and installed on the new hub. This was the case when I installed my Prototipo, not 100% sure about your particular case, but chances are it will. Does Pelican sell the cancel rings seperately? You can always ask customer support as well, they are very helpfull.
a.k.a. G-man
![]() It's the black plastic ring with the tab sticking out. (this one is a 914 wheel) As you can see, it is removed by unscrewing the screws.
a.k.a. G-man
This is your hub without the ring.
To be clear, the pin is a separate part aside from the cancel ring? I suspect the wiper switch may be going out, so I'm contemplating replacing both it and the turn signal switch while I have the steering wheel off. |
a.k.a. G-man
The pin you speak of is the tab on the cancelring, no?
It is a single piece, tab and ring. Good tip on the spacer!
a.k.a. G-man
Like this
I *think* that's what Pelican refers to on their page as the 'pin'.
a.k.a. G-man
Ok, talking about the same thing.
It's not a seperate item. I didn't realize it was that expensive, wow, 150$.
Sierra Madre had it for $117, but they are out of stock. Ahh, the Porsche tax.
a.k.a. G-man
I’d use the one you have.
New would be a stretch; all the new ones tend to have the seam now. When I first used to drool over the photo here, they didn't. Aitwe changed the way they made them. I have an old wheel, which I find suits the interior of my 250K mile, 40 year old car much better than a new one in any case. Some people bang on about them being "different" or somehow "better". It's an Aitwe wheel, and the same typ 33 model has been around since the factory first fitted them to the ClubSport (and they were also sold as the "formel" or "Indianapolis" wheel to fit just about every "sporty" car in Europe around the same time - also a Ford OEM option on Cosworth turbos and RS models). Wayne said once that any leather variations (eg bumpy, smooth, grain size etc) were just batch/manufacturing differences. Quote:
But, Special Wishes aside, if the horn pad has a metal crest, it's not factory; it's an Aitwe with a badge - usually a 356 deco or door pull badge - someone stuck on/through the pad. Horn pads, screw kits, horn ring kit, horn repair kit (the plastic snap-in ring for the pad), hub etc are all available separately. FVD carry most of this. So buy a horn pad and a badge and experiment, if you want. The KBA70111 wheels Aitwe supplied Porsche (which have the magic triangle P mark) have an embossed horn pad. These also listed in PET (in different colors, yet), as replacements for the items fitted to the 968 ClubSport. Don't know if anyone ever managed to get one. All the 911 ClubSports I've seen photos of had the 4 spoke, not the Aitwe. But unless it got taken off a 968, then it's an aftermarket wheel. Either supplied by Aitwe to Porsche and sold via Techquipment (aka Porsche), or straight from Aitwe to any one of a myriad of resellers. Quote:
In actual fact, I thought my Momo was a slightly better wheel on that grounds that it's just slightly smaller diameter and so interferes less with visibility of the (rotated) instruments, as the circumferences lines up better with the "empty" areas and you didn't have to look around/over it. But I do prefer the look of the plain Aitwe wheel, and find the narrower padding/smooth covering more to my preference.
'77 S with '78 930 power and a few other things. |
