| spuggy |
03-09-2020 06:11 PM |
Originally Posted by Reuben911
(Post 10777058)
Hi
Changed my steering wheel to momo prototipo. Can't see my speedo and had to tilt it so I can read up to the maximum speed limit (still not clearly visible)
I want to swop my tachometer for the speedometer and was wondering if anyone done this and is there enough slack on the wiring to swop around.
Take a look at enough interior photos here, and you'll notice many cars with smaller steering wheels have the gauges rotated. It looks pretty haphazard until you sit behind the wheel, then it all makes sense.
Rotate the gauges so you can see the important bits of the instruments over/through the wheel without craning your head around too much.
For example, I can easily see the 10-80 MPH range on my speedometer, and my RPM needle stands straight up at "12 o'clock" at the optimum shift point for my cams.
If I'm making boost with good oil pressure, I know what the speeds are in each gear...
