Tachometer speedometer swop
Hi
Changed my steering wheel to momo prototipo. Can't see my speedo and had to tilt it so I can read up to the maximum speed limit (still not clearly visible)
I want to swop my tachometer for the speedometer and was wondering if anyone done this and is there enough slack on the wiring to swop around.
South Africa, 1984 Porsche 911 3.2 RHD
Old 03-09-2020, 01:25 AM
49willard
I can't answer your question, however, responders should note that your 911 is RHD which could make a difference
Bill
1961 356B coupe-long gone!
1986 Grand Prix White Cabriolet
Old 03-09-2020, 03:11 AM
RDM RDM is online now
Coram Deo
RDM's Avatar
Umm... they aren't the same size. Unless you're going to swap the internals as well, which seems complex and expensive.
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 03-09-2020, 03:26 AM
Oops, did not realized that the tachometer is much larger
Old 03-09-2020, 07:30 AM
Originally Posted by Reuben911 View Post
Hi
Take a look at enough interior photos here, and you'll notice many cars with smaller steering wheels have the gauges rotated. It looks pretty haphazard until you sit behind the wheel, then it all makes sense.
Rotate the gauges so you can see the important bits of the instruments over/through the wheel without craning your head around too much.
For example, I can easily see the 10-80 MPH range on my speedometer, and my RPM needle stands straight up at "12 o'clock" at the optimum shift point for my cams.
If I'm making boost with good oil pressure, I know what the speeds are in each gear...
'77 S with '78 930 power and a few other things.
Old 03-09-2020, 05:11 PM
I had North Hollywood Speedometer redo my tach and speedo. Tach has redline straight up. Speedo has the 0 t0 80 on the left side.
RGruppe #79 '73 Carrera RS spec 2.7 MFI
00 Saab 95 Aero wagon stick
01 Saab 95 Aero wagon auto
03 Boxster
90 Chevy PU Prerunner....1990
Old 03-09-2020, 05:43 PM
7783911's Avatar
i used an eccentric hub adaptor to move the protipo up and can see gauges clearly now
Old 03-09-2020, 06:30 PM
