Removing rubber marks from paint after track event?
What should I use to get the rubber marks off of my paint after my track event this weekend. I washed the car but that wasn't enough to get the rubber streaks off the front of my car.
Old 04-13-2003, 08:05 PM
Super Moderator
cstreit's Avatar
I use 3 strengths on my white car for tire marks...
1. Goo Gone works for the easy ones...
2. If they still won't come out, 3M adhesive remover...
3. Once a year I use a cleaner wax with a buffer to get the stubborn ones.
Chris
1996 993 RS Replica
2023 KTM 890 Adventure R
1971 Norton 750 Commando
Alcon Brake Kits
Old 04-13-2003, 08:24 PM
a small amount of WD-40 on a soft towel will do the trick. Be sure to degrease the surface you just cleaned and then wax the area.
Chris
Old 04-13-2003, 08:29 PM
Stanley's Avatar
How do you get rubber marks on your paint from a track event? (I've never been a track event before)
'78 SC
Old 04-13-2003, 08:30 PM
Super Moderator
cstreit's Avatar
Stanley,
As tires scrub off, the rubber sort of collects in the "dead" areas of the track and turn into marble sized chunks of rubber. THose chunks or "marbles" get kicked up by cars and bounce off the cars behind them leaving little greasy rubber streaks... Mostly don't harm the paint unless they have a lot of grit in them...
Chris
1996 993 RS Replica
Alcon Brake Kits
Old 04-13-2003, 08:44 PM
gregk1's Avatar
Naptha is what I use to get all the rubber marks that build up on the corners of the slot car track ,works very well and doesn't bother the paint
65 911/ 301274 sold
66 911 /303509 sold
67 911/ 355032
68 911 softie sold
70 T with s trim
Old 04-14-2003, 05:44 AM
I use Mothers Cleaner Wax. It is the safest on your paint.Wurth Makes a product that is very good. Safety-Solve.
Old 04-14-2003, 06:16 AM
Amac's Avatar
Bug and tar remover works good for me.
Goo gone will works most of the time.
Put a heavy coat of wax on the area you
get the marks, keeps it from sticking so bad.
"Never go faster than you can stop"
85 - 930 (750hp)
Norwood motec 3.5 twin turbo
Old 04-14-2003, 09:36 AM
Chuck Miller's Avatar
If you have plenty of wax already on the car then... a little Paint Thinner (Mineral Sprits) on a damp paper towel just before washing does the trick for me.
Chuck Miller
'73S cpe #1099 - Matched # 2.7/9.5 RS spec rebuild
'67 Malbiu 327 spt cpe - Matched # L-79 rebuild
Creative Advisor/ Message Board Moderator - Early 911-S Registry
R-Gruppe #88
Old 04-14-2003, 09:46 AM
