project Weber Carbuerators Into 1973.5 CIS Motor
I am going to put Weber Carbs on my 2.4 CIS motor... (please do not try to tell me how great CIS is ... (it is out) Except the ALUMINUM COLLARS that the injectors and rubber Was in.... There in is the problem!! Can anybody tell me how they removed the ALUMINUM COLLARS and how You PLUGGED the hole ?????? At this point I have not taken the engine from the car, nor have I removed the heads off of the engine...(which I am sure will bring disparaging remarks) Help from someone WHO HAS DONE this will be truly appreciated... Thank You in advance !!!!!!
Old 03-09-2020, 03:30 PM
AutoBahned
RWebb's Avatar
drop the motor; remove pistons & cams and replace with ones for carbs
Old 03-09-2020, 04:13 PM
I would rather be driving
jpnovak's Avatar
Usually an allen cap screw is threaded into the rubber injector holder. PN 911.110.922.00
Other options include:
- custom brass or aluminum plugs that press into the top of the injector holder tube.
- remove steel injector insert and then plug using these method.
Old 03-09-2020, 04:45 PM
HarryD's Avatar
Originally Posted by jyporscheboy View Post
I am considering putting 40IDA Weber carbs on my 1973.5 911T .. Anybody have experience in this project .. Any help or suggestions will be greatly appreciated ..
You have been looking at this conversion since 2011. Why the extended delay?
Harry
1973.5 911T Targa - "Smokey"
2020 MB E350 4Matic
Old 03-09-2020, 04:48 PM
AutoBahned
RWebb's Avatar
must be from old gas
Old 03-09-2020, 04:52 PM
'73 911 T Targa
Sometimes these things require deliberation. I’ve been thinking about EFI on my 73 for about as long! ☺️
By the way, my 73 was converted from MFI to Webers and the injector openings were closed with threaded plugs. When I dream about EFI, I think about re-using those for the EFI injectors.
Old 03-09-2020, 05:24 PM
jpnovak's Avatar
I can help with that.
MFI to EFI
BTW, the 73.5 CIS heads will also accept EFI injectors. Works the same as my adapters but without the adapters since the factory already installed them.
Old 03-09-2020, 06:01 PM
'73 911 T Targa
MFI to EFI
One of my barriers is that although I still have my original throttle bodies, they are shot. So, in addition to an ECU and all the other stuff, I'd need to get throttle bodies.
That just sparked a thought...
Could I keep my Webers as just throttle bodies (after blocking all the fuel inputs) and use the injection ports in the heads ?
Old 03-10-2020, 09:44 AM
HarryD's Avatar
EFI requires a way to sense the air flow. Individual throttle bodies do not accomplish this.
Harry
2020 MB E350 4Matic
Old 03-10-2020, 10:31 AM
jpnovak's Avatar
Not True. But ITBs do require a port added to detect vacuum. Works just fine without TPS. You just have to know how to tune around the "wall"
Old 03-10-2020, 11:33 AM
Better in Person
juanbenae's Avatar
im not following??? if the 73.5 CIS mirrors the later versions aren't the injectors seated in the intake runners that would be removed for carb based manifolds? or could you be referring to the plugs required in the heads like the 74-79 air pump equipped cars after you remove the spider manifold ?
sorry if im way off base not being familiar with the earliest CIS systems. ive removed CIS for carbs on two early, large post 3.0L motors over the years so those are more in my wheel house.
Old 03-10-2020, 12:19 PM
AutoBahned
RWebb's Avatar
I think the best thing to do for the OP would be to buy a 3.2L and either swap it in as is, or hotrod it while driving with the 2.7 CIS then swap. Sell the CIS motor later.
Old 03-10-2020, 12:20 PM
Better in Person
juanbenae's Avatar
OK, did a bit of research and found this EFI conversion thread. 2.4L Mounting CIS intake for EFI Conversion
I have a better understanding now, so my suggestion is place a WTB add in the classifieds and get a proper carb manifold. you can get the isolation spacers that block off the groove in the head intake and insulate the carbs from both heat and vibration from the motor.
Old 03-10-2020, 12:35 PM
HarryD's Avatar
If this is the case, then I have been schooled. Thanks!
Harry
2020 MB E350 4Matic
Old 03-10-2020, 02:31 PM
HarryD's Avatar
The 1973.5 CIS motor is unique in many ways. One of them is that the injectors are in the heads not the intake runners which started in 1974.
1973.5 induction (note the injector ports in the head):
1974 induction (note injector ports in the runners):
Harry
2020 MB E350 4Matic
Old 03-10-2020, 02:39 PM
jpnovak's Avatar
Excellent visual reference Harry.
Old 03-11-2020, 03:48 AM
'73 911 T Targa
Sorry for the novice question, but am I correct to assume that the need to detect vacuum makes it a non-starter to use Webers as ITBs?
Novice question #2 - could ports be added?
Old 03-11-2020, 12:50 PM
Charles Freeborn's Avatar
Harry is quite right. The 73.5 was a special beast with heads more similar to the MFI cars, few of which came to the US. I haven’t studied that era in depth (mine is. ‘74) but I’m guessing that just like the rest of the CIS cars you’ll need to change pistons and cams to see any real improvement in performance. The CIS system needs a specific cam profile that does not work well with other induction systems.
Old 03-11-2020, 01:34 PM
I have a nice pair of 964 Camshafts with only 150 miles on them. These would work well with you motor with carburetors.
Old 03-11-2020, 03:28 PM
