| Registered |
				What type of caliper is this?
			I'm trying to figure out which type of caliper I have. It was extracted from a 1980 SC but I don't know the history on the vehicle to be confident this was a stock caliper.  Any ideas? P.S. yes, I was messing around with new blast media on one side :-) | ||
|  03-11-2020, 09:26 AM |
| RETIRED |
			Stock
				__________________ 1983/3.6, backdate to long hood 2012 ML350 3.0 Turbo Diesel | ||
|  03-11-2020, 11:25 AM |
| Registered |
			So an "A" type caliper?
|  03-11-2020, 11:54 AM |
| Registered | |||
|  03-11-2020, 11:59 AM |
| Moderator |
If it came off the front, If it came off the back it's an M A difference between a & M is the pads width and th mounting hole OC spec. an A has 3.5" OC mounting holes and an M has 3" OC mounting holes
				__________________ Bill Verburg '76 Carrera 3.6RS(nee C3/hotrod), '95 993RS/CS(clone) | Pelican Home |Rennlist Wheels |Rennlist Brakes | | ||
|  03-11-2020, 12:05 PM |
| Registered |
			Thanks all. This came off the back so should be an M then.
|  03-11-2020, 02:33 PM |
| Registered |
			BTW Bill, your Rennlist Brakes link in your sig is broken.
