-   -   Rear View Mirror Location (http://forums.pelicanparts.com/porsche-911-technical-forum/105503-rear-view-mirror-location.html)
pryord 04-07-2003 03:04 PM
I had my windshield replaced, and the mirror seems awfully low now. I don't recall it obstructing my vision so much. Can an SC owner tell me the correct distance from the top of the windshield to the mirror?
Thanks!
Eric Coffey 04-07-2003 03:15 PM
If I remember right (from replacing mine a while back), The center of the mount was 4.25" down from the top seal.
RoninLB 04-07-2003 05:21 PM
you may want to tweak the position.. depends if you got a roll bar or not a tall guy.. cast an eyeball thru the mirror to rear on a level ground........Ron
jmohn 04-07-2003 05:21 PM
Be aware if you put it up too high on the windshield it will interfere with the sunvisors, when their flipped down, like it does on mine 'cause some previous idiot reinstalled it without checking. I've spent two years trying to, carefully, get that sucker loose without breaking the winshield.
Jerry M
'78 SC
RoninLB 04-07-2003 05:43 PM
heat gun the inside mirror piece, then heat gun from outside.. it'll loosen the glue...............Ron
RoninLB 04-07-2003 05:47 PM
Oh yeah Minnesota cold man..
bring up the temp of the whole windshied slowly to help prevent a crack.........Ron
jmohn 04-07-2003 06:01 PM
Ronin-
I'll give it a try again (carefully), I was been concerned too much heat would also affect the windshield (it was winter here 'til recently). The guy who installed it last used epoxy or "mirror adhesive" not the OEM double-sided tape, so I've been trying to be very careful.
Thanks,
Jerry M
RoninLB 04-07-2003 06:06 PM
Ronin-
Oh!!!
I think it may be the hard stuff.. I don't think the hard stuff will give.. maybe buy some and test it, or call the mfg.............Ron
pryord 04-08-2003 07:06 AM
4.25", huh? Well, then the "Porsche experts" who replaced my window were more than a little off.
Thanks for the info!
