I can't remember how small the male/female connections are inside that big connector. You may need to get your craft on and find a small adapter (e.g., sewing pin/small wire) that allows you to check the female side of the connection. I have never done this but check both wiring harness side and Lambda side for ground. What do you use to check duty cycle? |
Do I need to have the key in run or off or either battery post disconnected? I pulled the connector under the seat and could not find pin numbers. Is there a pin diagram somewhere? Am I looking for the same voltage or resistance at each pin or can I just use a test light to test continuity? I have two DVM I use to check DC. Also have 2 dwell meters but they are both showing a needle reading of 6% when 8 cylinder is selected which does not seem right. Thanks |
He refers to the big plug connected to the ECU below the passengers Seat.
So, Below 15°c the switch leads to ground, ... At 15°c that switch opens the circuit. When o2 Sensor is disconnected above 15°C the ecu switches to a static 50% duty cycle, where i.E. in this state you also adjust the CO value. Quote:
You should better use a DMM with duty cycle Option. |
I will look for a powered dwell meter. They are getting a bit hard to find on eBay Both my DVMs have HZ%. Thanks |
I believe the 15C switch is working properly. It goes to 65% when grounded. It is almost never below 20C here. If it were the switch would ground and take the FV to 65% if O2 disconnected. It’s either the O2 circuit or the OXS ECU that is not doing what it should. I will be investigating further today I hope.
And tell us the bosch part No. of your ECU on its sticker. Quote:
Just remove the o2 sensor and lead the red terminal of your DMM to the inner contect of the 02 sensor socket in the left engine compartment, black to ground ... you should read 0.5v with engine running (otherwise the ecu wont get any current). Quote:
Touch the probes together. Does it beep? If yes you are able to now see if the ECU wiring harness or the ECU pins are talking to the chassis of the car via continuity. That's a ground. If we figure out the right pins you should be good to test. This is the 14 pin connector off of a 911 turbo, the one by the rear bumper left side. It routes power to a bunch of stuff in the engine like in your car and does not manage The Lambda system. Just want to make it perfectly clear that the 14 pin connector is not where you want to be. http://forums.pelicanparts.com/uploa...1591112677.jpg Now the 10 pin connector between the shock towers delivers power to the frequency valve through the #1 pin if I remember. That may have been OP's issue with rough running and backfires when under load but he has not been online here for a couple of months. Focus on the ground concept and I'll see if I can scrounge up a pinout diagram for the ECU connector. |
I have checked the 15C switch as you said. It checks good.
Found the pins for the OXS ECU in Bentley. They are not diagramed in order so that confused me a bit but they are numbered and the numbers match the wire colors on my plug
http://forums.pelicanparts.com/uploa...1591113332.jpg Got continuity readings as follows. These were done by setting the DVM to Continuity and one probe on the pin number and other probe on the wire end. http://forums.pelicanparts.com/uploa...1591113563.jpg Pin 2 to O2 sensor. .2 ohms 5 GRND. .2 7 to 15C switch. .3 ohms 8 to OXS relay. .4 12 ECU to AEC and 15C switch .1 14 ECU to AEC. .1 15 ECU to FV to OXS relay. 2.8 ohms AEC is Acceleration Enrichment Control Unit http://forums.pelicanparts.com/uploa...1591114051.jpg Got .5 VDC here with fuel pump jumpered and key to run. Is this the right way to test it? |
Check for harness terminal to chassis continuity. Check the OXY box terminals for same (although I am not certain this will show anything if the box is grounded through a terminal in the connector - which is disconnected) |
Well, I think that's the resistance setting but yes. No or little resistance means continuity. Obviously a bare metal part of chassis. |
I also have a test light if that makes anything easier
You can use the negative post on the battery as the "chassis" point if you wish but then you have to run extra wires to bridge the distance. |
| All times are GMT -8. The time now is 04:51 PM. |
