Lambda controller, right? It's not that difficult, actually less complex than controlling the mixture. |
Let the CIS give you lambda 1 and your box allows everything (well almost) that you would want a 3D mappable solution to do without any of the hassle..... Sorry for thread hijack! |
thats what I've been thinking about also. Reading/passing the (TD) trigger signal between the dizzy and the CDI. But as till now I was totally in that process of coding/testing/coding etc. of the lambda core, this could be a forthcoming option. |
the distributor signal. |
So with this sensor in regular the lambda 0,85, needed for Acceleration, can only be guessed but I found out how much more duty cycle is needed for a proper hit. The "static 65% duty cycle way" often results far off and for shure with a factory initial CO setting of 0.4 - 0.8% Vol. at 50% duty cycle. Your wanted approach can be achieved with the wideband sensor, but also here for a functional "pseudo mapping" many more signals must be read like the rpm one from the speedometer/CDI, a manifold vacuum sensor signal etc etc. This is possible but makes the unit very user specific addressed, means a typical 911 DIY "make the best of it" user who is very in mechanics electrics etc. ... lets see :-) I already temporarely used the rpm signal in the ECU for playing a bit with it – i.E. switching the FV off when deaccelerating – the whole SSIs changed into a nice popping beat box animal which sounded like hell – well at least for 911 sound freaks heroes ;) Quote:
As its still dealing with Dwell, Duty Cycle, ECU and more |
@ Sub8
Here a video where the needed lambda 0.85 spot for accelerating is perfectly hit and kept when using a wideband sensor with this ECU. https://vimeo.com/409686215 |
Great effort on your part. You should have no problem designing an ignition system. A simple design without ignition maps is possible by using an equation to replicate a basic distributor advance curve. |
Checked connector outs 12 and 14 got OL on both. No ground. Out of a bit of frustration I then unplugged the lambda ECU, car almost died, richened the mixture and set mixture by the “lift the air plate 1mm” method. Took it for its first drive in a month and it ran great. So is my lambda ECU bad? If so what next? Thanks |
2. When running with the ECU connected and the back of the connector cover removed, measure the voltage at pins 2, 7, 12, 14. |
I have 2 other O2 sensors that tested good today. I will put one in tomorrow and see if it works better. |
But I guess here your focus should be set on the ECU – just follow what mysocial911 suggested 2 posts before and let us know your readings. |
(pins 7,12,14 must be above 5 volts, pin 2 at about .50V). |
Are you sure with 12 and 14, ... as these lead to the Acc. enrichment unit and AFAIK this includes Schmitt Trigger components, so for me this sounds like affecting the PWM signal where no constant voltage is present. Or am I on the wrong way?
Also 7 leads to the "15°C temp"/"35°Throttle" switches which simply lead to ground when cold or accelerating, which would cause a short circuit if voltage would be present on this wire on the side of the ECU. http://andrewcologne.bplaced.net/911...rcroswitch.jpg |
Actual voltage measurements from key inputs pins of various Porsche 911 Lambda ECUs:
0 280 800 055 2 - .53, O2 input 6 - 12, no Lambda effect (NLE) 7 - 12, enriches at ground (EAG) 9 - 5, NLE 11 - 12, EAG 12 - 12, EAG 0 280 800 006 2 - .53, O2 input 6 - 12, NLE 7 - 12, EAG 9 - 5, NLE 12 - 12, EAG 0 280 800 037 2 - .53 O2 input 6 - 12, NLE 7 - 12, EAG 9 - 5, NLE 11 - 12, EAG 12 - 12, EAG So for the Lambda ECU (055) in this thread with no O2 sensor and pins 7/11/12 open, a 50% DC should result. It's that simple! |
... wrong thought, .... deleted.
http://forums.pelicanparts.com/uploa...1591640267.jpg Car running, ECU connected, AEC unplugged: Pin 2 is .5V Pin 7 is 13V Pin 12 is 13V Pin 14 is less than 1V With AEC plugged in: Pin 14 less than 1V |
Ringing from the frequency valve pulses can distort DC measurements with some meters, here DC is actually 50%,
but some meters could indicate 83%; http://forums.pelicanparts.com/uploa...1591653301.JPG Closeup of ringing; http://forums.pelicanparts.com/uploa...1591653411.JPG Proper DC (50%) using a test light; http://forums.pelicanparts.com/uploa...1591653553.JPG Therefore, disconnect the FV and use a test light as the FV, alligator clip to +12V and other end to FV connection at pin 15, and measure the DC. |
| All times are GMT -8. The time now is 07:32 AM. |
