SC Flywheel Specs
Anyone know where I can find specs for 911 SC flywheel in order to determine if mine has been or can/should be resurfaced? Searching old posts here is says "just look in your Bentley manual". Well, I'm looking and can't seem to find it anywhere. Any and all help appreciated, even if it's right in front of me.
Thanks in advance, Craig |
Wear limit on the thickness is 8.5 mm. If you think it needs machining I would just replace it.
Walt 82SC 3.0 81SC 3.6 |
Thanks Walt, minimum 8.5 mm. thickness from clutch surface to back side of flywheel?
Craig |
Correct.
