Poll: What would you do?
Be advised that this is a public poll: other users can see the choice(s) you selected.
Poll Options
What would you do?
TeamAguilar's Avatar
Talking Core exchange or keep the 3.0?
Just wondering what you would do.
My 1979 3.0 needs a total rebuild. I am going to purchase a rebuilt 3.2 but wondering if I should keep my 3.0 or do the core exchange. I have had the car since I was 5, it was my moms, I have kept it all original but I don't care about numbers matching up. I'm never going to sell this 911.
Part of me would like to get another early model 911 down the road and perhaps I should keep this engine to rebuild for that car???
Maybe this 3.0 isn't worth holding on to and I can just get another rebuilt 3.0 or 3.2 down the road for that car? And that's a big if because I don't even have that next car yet.
What would you do?
1979 911sc owner in San Diego. My first post and story on the Pelican Forum can be read here - http://goo.gl/7WZjp
My favorite website can be viewed here - http://goo.gl/MPWUA Thank you, this is a great forum!
Old 06-10-2020, 11:37 PM
El Duderino
tirwin's Avatar
I’d be tempted to keep the 3.0 if storing it is not an issue and you’d be happy with the displacement down the road.
My reasoning is that these motors are not going to get cheaper so if you get out now and try to get back in later, you’re losing money.
Even if you decide down the road that you want a higher displacement 3.2 or 3.6 the core value of the 3.0 will also be more valuable. Maybe not a lot, but some.
Edit: The advantage of a complete 3.2 or 3.6 is more modern engine management. If you wanted to convert to something like EFI/ITB then it’s a moot point as you’ll likely discard those bits. The 3.2 and 3.6 are probably cheaper starting points in the sense that you have more affordable HP upgrade options. If I were going to start a project car CIS wouldn’t be at the top of my list for a starting point.
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 06-11-2020, 03:16 AM
walt's Avatar
I would keep it at least short term if you have the space and are at least thinking of a project car at some point. You could always sell it later and probably for a bit more than is currently offered as a core exchange.
Walt
82SC 3.0
81SC 3.6
Old 06-11-2020, 05:16 AM
gearhead
Keep your car numbers matching. Build your 3l as a 3.2.
1974 914 Bumble Bee
2009 Outback XT
2008 Cayman S shop test Mule
1996 WRX V-limited 450/1000
Old 06-11-2020, 06:00 AM
I would keep it with the car.
I'd let your goals and cost dictate if you put it on a shelf for later or rebuild it for the car now.
Assuming I had the funds to burn at the time, I would likely install another engine in the car and take my time rebuilding the original 3.0 as an enjoyable project.
Old 06-11-2020, 06:29 AM
3rd_gear_Ted's Avatar
Create a SoCal hybrid bastard child and have fun.
A 3.6 Mezger is the premier air cooled motor.
1980 911 - Metzger 3.6L
2016 Cayman S
Old 06-11-2020, 06:32 AM
Keep the 3.0
Keep the original 3.0. The early U.S. spec SC’s have better flowing CIS/heads and are easier to build into a powerful and free revving engine. Drop in higher compression pistons and 964 (or similar) cams and SSI’s with a free flowing exhaust. If the budget allows, a Max Moritz 3.2 P&C swap is a proven upgrade.
If the 915 needs “attention,” consider shorter gear sets for a mechanical advantage.
Old 06-11-2020, 07:07 AM
