gtc gtc is offline
abides.
gtc's Avatar
Replacing Charcoal Canister on 3.2
I recently discovered that the charcoal canister on my 1984 Carrera was cracked, so i found a nice replacement from ebay (via Autobahn Dismantlers, apparently from a 3.6 but they say it is 3.2 compatible).
It appears to be the same size as the old one, and was a lot cheaper than a new canister from the dealer.
I was just curious, though, does it matter how I orient the canister when i install it? For instance, should the engine connection be on top, so that it is less likely to pull in any liquid that condenses? (I'm not even sure if liquid collects in these)
Also, the fresh air vent is on the opposite side, so the U shaped hose would be pointing the opposite direction in the car... should i snip the end of the hose off so it is pointing the same way as before?
Am I overthinking this?
Diagram from the 3.2 PET for reference:
3.6 Canister pics:
Graham
1984 Carrera Targa
Old 03-23-2020, 03:01 PM
Charcoal Canister thread hijack
Sorry I cant answer you Graham, but have another question on your subject.
Do these Canisters need replacing after a certain time or mileage?
I have a 1973 with 140,000 miles and looks good from the outside.
Old 03-24-2020, 01:56 AM
Flojo's Avatar
delete it. way simpler than chasing a replacement or worrying about failure.
Regards, Flo / 79 SC streetrod - Frankfurt, Germany
Instagram: @elvnmisfit
Old 03-24-2020, 02:23 AM
It is required for areas that do emissions testing. You will notice more gasoline smell in a garage without it. It really does have a purpose.
Old 03-24-2020, 07:20 AM
gtc gtc is offline
abides.
gtc's Avatar
How do you plumb it when you delete it? Do you connect the tank vent to the air filter port?
I do not need to go through emissions testing, but I also don't like smelling gasoline, so i'll probably keep it.
Mine was definitely bad, as it would let some little charcoal bits in to my air filter housing. When i was using the stock 3.2 airbox it was acceptable, as they would just fall to the bottom of the airbox, but if i connected the canister hose to my MSDS cone filter adapter they would go straight through the AFM and in to the engine. Probably not great for the motor.
Graham
1984 Carrera Targa
Old 03-24-2020, 10:28 AM
When I purchased my 1988 3.2 there was no canister and I have never smelled a gas odor in the garage. Given that, where was the canister?
1988 Carrera coupe
1966 250 Ducati
2015 VW Golf TDI gone because Dieselgate!
2021 VW Golf TSI
2014 Ninja 300
Old 03-24-2020, 11:30 AM
That's fond- just deglaze
Hi GTC- Hopefully, several pictures are worth a few words. I was able to source an OEM version 928 201 014 04 several years ago (1986 3.2 Coupe). I intend to install, but here's a full overview, including the factory original part still in its original location. It seems to me, you don't even need a hose for the "Luft" (Ambient Air) nozzle on your replacement part, as it's already pointed in the right direction. I suspect someone at Porsche realized that the part could be simplified for the 3.6 by simply having Purolator revise the design. One less hose, clamp and strap!
Cooking on a Porsche 911- The compound butter made the difference
https://www.youtube.com/watch?v=FvXBR50rH9E&t=1s
Missed Approach
Petra- 1986 Coupe
Old 03-24-2020, 12:43 PM
proporsche's Avatar
This...guys do not overthink it..i have my 911 over 24 years and never ever i had a smell from gasoline.I have removed the canister the 1st week i got the 911.....
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 03-24-2020, 12:52 PM
gtc gtc is offline
abides.
gtc's Avatar
Thanks for the photos and suggestions. Seems like the motor connections is always on the bottom, so I'll do the same when I install the new one.
Graham
1984 Carrera Targa
Old 03-25-2020, 10:42 AM
Shaun @ Tru6's Avatar
I deleted mine in my 84 after finding little carbon pellets in the air box. No adverse effects.
Tru6 Restoration & Design
Old 03-25-2020, 10:46 AM
gtc gtc is offline
abides.
gtc's Avatar
Shaun, what did you do with all the hose connections?
Graham
1984 Carrera Targa
Old 03-25-2020, 10:52 AM
I don't remember exactly, I'll look after work today Graham.
Old 03-25-2020, 10:55 AM
gtc gtc is offline
abides.
gtc's Avatar
Don't worry about it, i was just curious. I already have the new canister, so I will still install it regardless.
Graham
1984 Carrera Targa
Old 03-25-2020, 10:58 AM
Ok.
Old 03-25-2020, 11:00 AM
Hi I'd be interested to learn how to best disconnect the charcoal thing.
I expect an obstructed line or cannister somewhere, since my gas tank pulls a strong vacuum as gas is used during driving.
For a long time I "solved" this by not fully turning my filler cap tight.
I'd rather put a cap on the airfilter box, distegard the cannoster and allow air into the tank at some place else as breather.
Thanks for any suggestions !
(I have a,late 1988 3.2 by the way, ROW, 1st delvery Germany)
Better a good one for a lot of bucks, than a bad one for little
Old 05-05-2020, 04:35 PM
gtc gtc is offline
abides.
gtc's Avatar
My vent lines were all very old and deteriorated, especially the ones in the fender and engine compartment. I am still slowly working back towards the tank, but the new charcoal canister and nearby lines seem to have fixed my vacuum issue for now.
Graham
1984 Carrera Targa
Old 05-05-2020, 04:42 PM
Fixer's Avatar
Unless you like the added weight back there toss it!!!
They're heavy too
Old 05-05-2020, 07:45 PM
carreradpt's Avatar
No one answered the question of what to do with the lines if you remove the canister.
Dan T
'85 Carrera
Dansk premuff/sport muffler
7's and 8's, Steve W chip
Kuehl AC and fresh top end
Old 05-06-2020, 11:55 AM
I won't be able to look for a few days.
Old 05-06-2020, 11:58 AM
GG Allin's Avatar
I just removed mine, if anyone is looking for one.....
1988 911 - 3.6
1999 SL500 - Gone
1995 M3 - LS2 - Gone
1993 RS America - Gone
Old 05-06-2020, 05:28 PM
