Rick
I am thinking about buying the Harbor Freight shop press ($119). Would this 12 ton press be adequate for most pressing tasks?
Rick 1970 911 E purchased in Stuttgart in 1973 |
The 9 Store
Our shop has the 20 ton. Works well. Not much more than the 12.
All used parts sold as is. |
I have used the 12 ton, a friends, and some parts were bent. If the structure of the 20T is better it may hold up better.
It will do some stuff. Better get the 20T
1+ on getting the 20 ton. You'll thank yourself in the long run!
Craigslist probably has a lot of top quality ones for cheap.
Slow old car
I used a super coupon and got the 20 ton. I use it so much, I don’t know what I did before I had it. Great tool.
Mike 1980 911 SC 3.1 Coupe // 1986 VW Vanagon Syncro EJ22 // 2015 Macan Turbo // 2017 i3 REX |
There are several threads on the Garage Journal and other forums about the different models of HF presses. There are quite a few improvements that many have documented.
Mark '83 SC Targa - since 5/5/2001 '06 911 S Aerokit - from 5/2/2016 to 11/14/2018 '11 911 S w/PDK - from 7/2/2021 to ??? |
I have the 20 ton, mounted it to one of there furniture moving dollies, so I can move it around the garage if needed. The 12 ton is much weaker, The 20 ton is really nice tool for the money.
David |
I bought the HF 20-ton when it was on sale and I had a coupon, so it was real cheap. It was the best investment and I have use it a lot and never had an issue.
-Dennis |
Rick, you can get a lot done with a 12 ton press. You'll only need more pressure if, for example, you take on challenges like a 996 transmission. I've used a 12 ton press to r&r Cayenne wheel bearings, which are darned big. I don't think there's anything on your '70 that will be a challenge for a 12 ton press.
The Harbor Freight stuff comes with caveats. Friends at another local shop got one of their 50 ton presses (or thereabouts), seals leaked in the first year. They replaced the seals, it's okay now. Me, I am really reluctant to buy equipment that is of questionable quality when its failure could seriously harm me. I like my fingers, eyes, genitals, etc. OTOH, I saw today that HF has donated their inventory of masks, gloves, etc to hospitals in need. Big props to them for that. We should patronize them!
Kevin Catellus Engineering catelluseng@gmail.com http://www.catellusengineering.com https://www.facebook.com/catelluseng/ Last edited by kevingross; 03-24-2020 at 07:16 AM.. |
Stranger on the Internet
I had one of those 12T presses. I welded up a new frame for it to stand on, because the original was flimsy angle iron. I also had it on a car skate, so I could move it around the garage.
If I ever felt it was doing something for which it was stressed, I stood on a small ladder in front when I pumped it. That way, when it ruptured, I wouldn't get a direct hit from the shrapnel.
Patrick E. Keefe 78 SC |
scumbag
The VW/Audi shop I used to work at has been using a 12T HF press for over 10 years. It's yet to fail. If you have a big 4x4, or a diesel truck that you work on, sure buy the 20T. For a classic 911, the 12 should be just fine. (that's what I have.)
Mine is on casters and I put a SWAG Offroad printed knob on the release valve. It's not a complicated machine and can be fixed/modified for cheap.
My first Porsche - http://forums.pelicanparts.com/porsche-911-technical-forum/989493-my-low-budget-dream-car-build.html AchtungKraft #009 - IG: @doktor_b |
I have that 12T press for close to 10 years now. There has been only one time when it needed a larger press. Having said that, if I bought another press, it would be a 20T press.
Porsche 2005 GT3, 2006 997S with bore-scoring Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS Disposable Car: BMW 530xiT, 2008 Mini Cooper S Two-wheel art: Ducati 907IE, Ducati 851 |
Iv got the 20 ton for 6 or 7 years now. Its great never had any trouble with the ram other than leaking out the handle pump. The plates broke but they were the cast ones i think they sell better ones now. Also the top beam started to buckle so i replaced it with a huge I beam. I very much abuse it. I might box the bottom beam next but i flip it occasionally. Recently upgraded to the air assisted ram and its very helpfull for repetative work
82 SC , 72 914 |
