Rennline window crank fitment issues
so the wizard jimtweet is covering my car in leather.
the new rennline window cranks seem to not fit and will destroy my door panels.
has anyone run into this issue?
Old 02-22-2020, 07:38 AM
proporsche's Avatar
i assume under the crank is the black plastic spacer??If yes add a plastic washer under that one,it will give you another 3 mm
Ivan
1985 911 with original 502 191 miles...808 198 km
Old 02-22-2020, 08:11 AM
7783911's Avatar
Ivan
What size washer?
Tx
Old 02-23-2020, 07:39 PM
proporsche's Avatar
show me your cank of the door..i`d say 3mm plastic washer should do..same size as the original if you have it there..can i see that one too?
Ivan
Old 02-24-2020, 12:41 AM
Registered Minimalist
75 911s's Avatar
I documented this problem a few months ago in an IG post. I tried a variety of spacers. The stock handle has quite a bit more angle than the Rennline version. Mine rubs and I haven't spent the time to fix it yet. If you put the stock one next to the Rennline version there's like a 1/4" clearance difference.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage
Check out my 75 and 77 911S build threads
Old 02-24-2020, 04:43 AM
Might stick some felt on the backside of the crank arm.
Ass-engine Nazi slot car -- PJ O'Rourke
Old 02-24-2020, 07:09 AM
gtc gtc is offline
abides.
gtc's Avatar
Send Rennline an email about it... they are fairly responsive.
Graham
1984 Carrera Targa
Old 02-24-2020, 10:23 AM
i did
"Blake,
Those door cranks are made to the same spec as the factory ones so we did not end up make a variant. Are the door cards bowed at all?
Old 02-24-2020, 10:33 AM
Some door panels are puffier than others. Space out the handle at the stem to remove the rub.
Sherwood
Old 02-24-2020, 10:47 AM
Sherwood
my panels were redone in leather. there is no room left to space it
Old 02-24-2020, 11:04 AM
Harpo's Avatar
In addition to the rosette below an additional black plastic washer would push your door trim pannel inboard and hopefully give you more clearance
https://www.pelicanparts.com/More_Info/90155289120.htm?pn=901-552-891-20-OEM
Old 02-24-2020, 02:17 PM
You can space the handle outward as far as the drive spline engagement (handle and window wind stem) allow. A longer screw might help.
Old 02-24-2020, 03:08 PM
There is no ledge for the washer to rest on.
Photos?
Old 02-24-2020, 05:05 PM
[QUOTE=mrrolleyes;10763144]There is no ledge for the washer to rest on.
Photos?
See below:
Do you see where a surface a spacer (tube or equiv.) can be inserted?
The max. distance one can mount the handle away from the interior panel is limited by the male/female spline engagement between the handle and the window crank stem.
Other remedies require some fabrication; e.g. window crank stem or spline extension, etc.
Sherwood
Old 02-24-2020, 07:44 PM
75 911s's Avatar
i did
"Blake,
Odd because when I held the rennline cranks to a straight edge there is clearly less taper than the stock crank...
Stock:
Rennline:
Old 02-24-2020, 08:28 PM
7783911's Avatar
do how did this get resolved, i have a similar issue to resolve and the spacer idea seems logical..but what size and if needed and i assume it would be inserted between 6 and 7,
the conical screw to hold the handle, can a longer one be obtained and if so, can someone post a sources/part number?
thanks
Old 03-20-2020, 03:45 AM
75 911s's Avatar
I think OP returned his. I tried a few spacers, but either the spacer is visible (which looks bad) or the handle doesn't operate correctly with the spacer in place. I think they would work with a less puffy door card. I'm using the appbiz RSA cards fwiw.
Old 03-20-2020, 04:07 AM
7783911's Avatar
I will look to get a small spacer made that matches the dimensions of the crank, the issue may be the conical screw length?
Old 03-20-2020, 04:57 AM
Harpo's Avatar
Crap, I'm in the same boat. My new quilted (puffy) door trim panels will most likely interfere. I have not yet installed to confirm.
Old 03-20-2020, 11:43 AM
i spoke to rennline and they are looking into it. i sent them the photos from duane.
Old 03-20-2020, 11:51 AM
