-   -   Early Bamberg radio install photos- Need Help (http://forums.pelicanparts.com/porsche-911-technical-forum/1056356-early-bamberg-radio-install-photos-need-help.html)
speedster911 03-29-2020 02:03 PM
If you have an early Bamberg radio installed in your car ( 72/73/74) would you post photos of where your channel selector and mic are mounted.
Looking for guidance on where/ how to install the selector and how the mic cradle gets attached. This is for an early install- two mounting clips integrated to the case of the channel selector ( not using a metal bracket) Thanks for your help
speedster911 04-04-2020 08:59 AM
Anyone able to share photos? Thank you
stevie 77 930 04-04-2020 07:12 PM
Even though this isn't a first generation Bamberg, the selector (and mic) can be mounted to the underside of the ashtray.
http://forums.pelicanparts.com/uploa...1586056272.jpg
speedster911 04-05-2020 01:52 PM
curious where your mic is installed?
The challenge with the early ones is the channel selector has molded tabs as part of the entire unit, unlike the later ones with the metal bracket. The molded tabs are approx 6" apart. I am assuming but do not want to make a mistake that it would be mounted right of the ash tray as thats only spot that can accommodate that length. Any suggestions pelican experts?
speedster911 04-07-2020 12:34 PM
Bump for photos of early bamberg radio installs
speedster911 04-12-2020 04:15 PM
anyone????
bkreigsr 04-16-2020 06:36 AM
Bill K
http://forums.pelicanparts.com/uploa...1587047752.jpg
speedster911 05-28-2020 02:07 PM
anyone with photos of a bamberg Radio installed in a pre-center console car?
Need proper location for hand mic,
My channel selector is mounted to the right of the ash tray under passenger knee pad.
Thank you
