Early Bamberg radio install photos- Need Help
If you have an early Bamberg radio installed in your car ( 72/73/74) would you post photos of where your channel selector and mic are mounted.
Looking for guidance on where/ how to install the selector and how the mic cradle gets attached. This is for an early install- two mounting clips integrated to the case of the channel selector ( not using a metal bracket) Thanks for your help |
Anyone able to share photos? Thank you
Even though this isn't a first generation Bamberg, the selector (and mic) can be mounted to the underside of the ashtray.
1983 911SC 1977 930 Turbo (again) 2018 GTS 2023 Audi A4 '74 914 '76 911S '72 911T '73 1/2 911T '77 930 Turbo (all gone) Last edited by stevie 77 930; 04-04-2020 at 08:15 PM.. |
curious where your mic is installed?
The challenge with the early ones is the channel selector has molded tabs as part of the entire unit, unlike the later ones with the metal bracket. The molded tabs are approx 6" apart. I am assuming but do not want to make a mistake that it would be mounted right of the ash tray as thats only spot that can accommodate that length. Any suggestions pelican experts? |
Bump for photos of early bamberg radio installs
anyone????
cycling has-been
Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
anyone with photos of a bamberg Radio installed in a pre-center console car?
Need proper location for hand mic, My channel selector is mounted to the right of the ash tray under passenger knee pad. Thank you |
