			 Dept store Quartermaster
				bonehead mistake?
			I was just talking to my uncle (huge BMW freak, forgive him) and I mentioned that I forgot to oil my flywheel seal before I installed it.  He says pull the flywheel back off and do it right.  Keep in mind this was not on a rebuild this was just a partial teardown so I am sure an oil film was present, but how much?  Give it to me straight guys I will do what is right if I have to.  Thanks.
				Oh yea, all have on is the flywheel right now. Not that it should matter I guess.
			Cornpoppin' Pony Soldier Last edited by lendaddy; 04-11-2003 at 06:27 AM..  |
			 Senior Member
			Well...if you are sure there was oil, it should be ok.
			I recall that I put oil everywhere that one could put it in, lots of it. But if there was no oil at all..well the rubber will burn.
	Projects: 911 -72T EFI "964-look" "Smoky" 914 -71 1.7 D-JET "Rusty"  |
			 Senior Member
			He's speaking as a true BMW motorcycle fan ;>
			Greasing this area is religion for Beemer motorbikers. But then again, detaching a swingarm and sliding a trans back is a whole different kettle of fish from doing this on a Pcar. John
	'78 Targa in Minerva Blue  |
			 Irrationally exuberant
			Did you clean the oil off the crank before you installed the seal? If you didn't, I'd call it oiled.
			-Chris
	'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/  |
			No, I didn't clean it off, but the motor has been sitting for 10 months now.  I am thinking I should just do it right and have some piece of mind.
	Cornpoppin' Pony Soldier  |
			 Unregistered
			You can eiter roll the dice or make sure. I'd pull the flywheel and grease it, but I always loose my @ss in Vegas so I'm not a very good gambler.
			 Author of "101 Projects"
			It's probably a non-issue.  Still, you'd hate to have to fix it once the engine is back in the car.  I thought you were going to drop the engine again and seal it.  I like to put a bit of Curil-T on there for extra assurance (see the new book).  Okay, I would pull the flywheel off, but I also don't recommend reusing flywheel bolts, because they are stretch bolts.
			So, if you are going to use new flywheel bolts, then do it. If not, then don't. -Wayne
	Wayne R. Dempsey, Founder, Pelican Parts Inc., and Author of: 101 Projects for Your BMW 3-Series • 101 Projects for Your Porsche 911 • How to Rebuild & Modify Porsche 911 Engines • 101 Projects for Your Porsche Boxster & Cayman • 101 Projects for Your Porsche 996 / 997 • SPEED READ: Porsche 911 Check out our new site: Dempsey Motorsports  |
			Then again, I do know people who reuse flywheel bolts, and they haven't had a problem.  Use red Loctite if you do though...
			-Wayne
			Wayne, the motor is out.  It is on a stand in my garage.  I will do it over.  I don't need the anxiety.
			 Montana 911
			pull it and go with a lightweight flywheel if you don't already have one...they are quite nice!   I would take it apart and do it right.
	H.D. Smith 2009 997.2 S 3.8 PDK 2019 Ford Ranger Lariat FX4 Baby Raptor 2019 Can Am Renegade 1000R XC 2020 Yamaha YFZ450R  |
			You will probably have full oil pressure within 10 - 15 seconds at that end of the crank after startup, so I really don't think is is worth the trouble or expense!  Non-issue, IMHO!
	Warren Hall, Jr. 1973 911S Targa ... 'Annie' 1968 340S Barracuda ... 'Rolling Thunder'  |
 I thought something similar at first but then I thought about it some more and reconsidered. Since this is a seal, some part of the seal lip should be dry. I.e. The oil won't reach the outside of the seal (unless the seal leaks) so part of the seal might remain dry even though pressurized oil was only 1mm away. Does that make sense? Or does a seal initially leak a small amount until the oil pressure obturates/expands the seal? Inquiring minds want to know... -Chris  |
			Chris,
			obturate Thanks for the word of the day. Hadn't heard that one before.
	Neil '73 911S targa  |
			 Unregistered
			There is no such thing as a perfect seal. All seals are designed to leak but the leakage is supposed to be so small that it is acceptable. Lip seals (and mechanical seals) are lubricated by the product they seal. A very small amount of oil will leak past even the most perfect lip seal and lubricate the sealing lip. The leakage can be as small as a film only a few molecules thick. If a lip seal did seal absolutely 100% it would burn up in a matter of minutes, maybe quicker.
			We actually measure the amount of leakage on seals where I work, anything under 500 parts per million is acceptable. That is not very much leakage. It would take a lot of hours of run time to even make a stain at those rates. The designers are so anal that in a pefect design the liquid being sealed stays in a liquid form for 65% of the entire width of the sealing face and then flashes into a vapor from the friction creating a high pressure zone that can seperate the seal from the shaft like a buffer and also keep the rest of the liquid from leaking out. Darn, I gotta stop mixing work with Porsches. Last edited by sammyg2; 04-11-2003 at 12:40 PM..  |
			Ah Sam, you have shined the light of knowledge on this problem.
			much thanks, Chris
 -Chris  |
	Jake Gulick, Black Rock, CT. '73 yellow 911E , & 2003 BMW M3 Cab. Ex: 84 Mazda RX-7 SCCA racer. did ok with it, set some records, won some races, but it wore out, LOL[/B]  |
