LinkBack | Thread Tools | Rate Thread |
Caveman Hammer Mechanic
Yup! I replace every oil pressure hose every 10 years. Mostly to insure that the fittings don't corrode together. If the cad/zinc plating is good I take the hose to my local hydraulic shop and have new rubber hose sections grafted on. Some hoses have specific lay lines to orient the ends. I don't mess with oil pressure lines. I even replace the "S" supply tube every 5 years or so. Oil lines are easy, engine overhaul due to oil starvation, not so much.
1984 Carrera El Chupacabra 1974 Toyota FJ40 Turbo Diesel "Easy, easy, this car is just the right amount of chitty" "America is all about speed. Hot,nasty, bad ass speed." Eleanor Roosevelt, 1936 |
Analog Air Cooled
My S line is new! Lol.
86 Targa 91 964 13 6 SPD Cayenne |
The oil lines are on the scavenge side of the system. They are low pressure with oil and air being pumped to the cooler and to the oil tank. Very little stress on the hoses. That end of the crimp has no load in it. That is why the crack survived so long and even corroded. If that portion was removed, the crimp still works.
Point being, the rubber will likely fail before that region. |
Under the radar
Have you seen this thread? Blew oil line on Highway
Sherwood |
