CIS potential vacuum leak List
Looking to put together a vacuum leak checklist for my CIS. I know most of the usual suspects, but it would be helpful to get feedback for an area I might not consider on the CIS unit.
Bob
73.5T/first CIS
Old 04-13-2020, 06:29 AM
Pop off valve where it's glued to the air cleaner housing.
Old 04-13-2020, 10:37 AM
El Duderino
tirwin's Avatar
Injector o-rings and seals
all old vacuum lines. I’ve replaced most of the rubber with silicone.
Intake runners
There are those who call me... Tim
'83 911 SC 3.0 coupe (NA)
You can't buy happiness, but you can buy car parts which is kind of the same thing.
Old 04-13-2020, 12:26 PM
RDM RDM is offline
Coram Deo
RDM's Avatar
The airbox in places you can't see (underneath and / or in the back).
Incidentally, I saw the other night that plastic airbuses are available from Porsche for under $500 (gulp). Glad I had a spare that I could experiment on!
Dru
1980 911SC Targa • Petrol Blue Metallic • Cork special leather • Sport Seats • Limited Slip • 964 Cams • SSIs • Rennshifter
• 1990 250D Opawagen • 1995 E220T Sportline Familienwagen • 1971 280SE Beverly... hills that is • 1971 Berlina 1750 Faggio •
Old 04-13-2020, 12:56 PM
Vacuum leak.......
If you car has vacuum assisted brake booster, the braided hose from air box to metal tube before the tunnel and the curved rubber hose located near the booster.
Tony
Old 04-13-2020, 01:09 PM
Designer King
Paulporsche's Avatar
There is an aluminum pipe that runs from the AAR and/or the AAV and passes next to the oil cooler on top of the engine block. A hole can rub through there, causing a vac leak. Mine was almost through when I discovered it while removing the airbox.
Paul
Yellow 77 Sunroof Coupe/cork interior; 3.2L SS '80 engine/10.3:1/No O2; Carrera Tensioners; 11 Blade Fan; Turbo tie rods; Bilstein B6; 28 tube Cooler; SSI, Dansk; MSD/Blaster; 16x7" Fuchs/205/50 Firestone Firehawk Indy 500s; PCA/UCR, MID9
Never leave well enough alone
Old 04-13-2020, 01:23 PM
Crank case breather hose........
This picture was sent to me recently by ANDONI (Bob A.) while trying to investigate his cold start problem. The engine is a ‘74 CIS.
Tony
Old 04-13-2020, 01:37 PM
Great suggestions...…………….
thank you.
Is their a smoke test for leaks? Take a big puff of a cigar and just blow it around watching for where it might enter? anyone ever try this?
Old 04-13-2020, 04:31 PM
Here is a good post for testing:
Finding CIS vacuum leaks - the vacuum cleaner pressure test
I use Tony's method: Take off the rubber boot on top, seal off the throttle body with a latex glove and also the two hoses that were connected to the rubber boot. After you have sealed the system, pressurize it with continuous supply of low pressurized air from a smoke generator or compressor. If just air from compressor spray the areas listed above with a soapy solution. Get the latex glove partially inflated during the test and observe for any source of air/smoke. Good places to inject the air are:
1.) Brake booster inlet to the airbox on drivers side of airbox.
2). POV.
3). Intake runner’s #1 or #4 injection port.
Old 04-13-2020, 05:51 PM
I did try the cigar method but did not have any success. That's why I built a smoke generator for a few bucks.
Lou
Old 04-13-2020, 06:00 PM
