B&B Heat Exchanger (heater box) started rattling!
All of the sudden there is a very loud rattle from my engine. I thought it might be the tins as one seemed to be not tight. The noise is very prevent ant on a cold stares, as the engine vibrates a little more. Once its warmed up the rattle goes away at idle, but if you bog the motor down you can hear it clear as day. I crawled under the car and the passenger side heater box is the cause. It moves a lot more than the drivers side (both move a little), and putting your hand on it stops the rattle. They are B&B headers on a 964 motors.
So whats the cure?
Chris - Insta @chrisjbolton
1975 911s Insta: @911ratrod steel wide body, 3.6 conversion
1989 911 Carrera 25th Anniversary Ed (5th from the last car to ever leave the original Porsche factory assembly line)
2001 996 Turbo - ~54k miles
Old 04-18-2020, 06:24 AM
Spot weld them in a couple of places to the headers
Old 04-23-2020, 11:57 AM
