PO homemade steering bushing terror
I bought the Rennline bushing to get rid of a little play. I find a sheet metal looking bushing pounded in the column with no way to grab and pull out. It appears I have three choices:
-Leave it and deal with the play
-Remove the shaft and bearing to remove the bushing
-Push the bushing through.
The question is, if I push the bush through will it just ride harmlessly on the lower bearing?
It appears to be a solid ring of steel so it should not get caught in the lower bearing or jammed between the shaft and housing.
What do you all think?
Old 04-14-2020, 07:32 PM
Old 04-14-2020, 07:45 PM
echecsqueen's Avatar
Looks like your po and my pos were buddies.
Sent from my BBB100-1 using Tapatalk
1988 911 Coupe Granite Green "Frogger"
1966 912R Coupe Stone Grey outlaw -"'Tilda"
1978 924 White with Cork (Streetcar vs. Porsche - streetcar won)"Poindexter"
1984 924s Nile Green Metallic with bone (totaled it in the snow in Cleveland, Ohio)
1983 911 White with Cherry Red...gave away (not enough time or money to keep it running) in 2001
Old 04-15-2020, 04:19 AM
That's some pretty sweet git 'er dun right there
Sent from my Nokia 7.1 using Tapatalk
Old 04-15-2020, 06:14 AM
Drill a hole in the center then screw in a sheet metal screw then use a pair of dykes to pry it out.
Old 04-15-2020, 07:04 AM
What do the dykes do to help?
Old 04-15-2020, 07:07 AM
walt's Avatar
Could you dremel a small notch in the end then try and spin in out, of course depending on how tight that thing is shoved in there.
Walt
82SC 3.0
81SC 3.6
Old 04-15-2020, 07:11 AM
To narrow for a sheet metal screw but did think about trying to drill a hole. It appears to be a single sheet of metal.
To tight a space for a Dremel. It's not that tight, hence the steering wheel wobble.
It is loose enough to push through.
That is my delimma. If I push it through will it cause steering shaft trouble??
Old 04-15-2020, 07:31 AM
/ˈpɔrʃə/ PORSH-ə Fan
LUFTKUL's Avatar
Can you get the front of the car on blocks, maybe take the wheels off as well and get the hub back on to rock the steering shaft back and forth while trying to grip a piece of it? Maybe as the shaft turns a part of it may rise up to be able to grab onto it and pull?
1984 ROW Carrera Sunroof Coupe Schieferblau
1982 US SC Targa Moosgrun
1977 US 911S Sunroof Coupe - SOLD
Old 04-15-2020, 10:06 AM
walt's Avatar
Looks like a gap in the pic. Is it possible using a piece of stiff wire to make a small hook then fish it down there and try pulling. 2 gaps 180 degrees apart might work. Just throwing it out there.
Walt
82SC 3.0
81SC 3.6
Old 04-15-2020, 10:44 AM
I would rather be driving
jpnovak's Avatar
I would assume that it is a "split" bushing/shim and not an overlap version. Get some MIG welding wire and push through the gap all the way through the steering column. Then bend a J hook in the end and slowly pull back until you can grab the lower edge of your "shim". This might allow you to pull up enough to lift out the shim. If the gap on the "split" is large enough you might be able to pre-bend the J-hook and not go all the way through the column.
Patience will be key here.
Old 04-15-2020, 10:48 AM
Option 1 - get a pair of needle nose vise grips, grab the accessible edge and twist/rotate and pull.
Option 2 - get a Harbor Freight Stud Welder Dent Puller, weld a stud to the accessible edge and twist/rotate and pull.
Good Luck!!
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 04-15-2020, 10:57 AM
Wire cutting pliers. Diagonal cutters. AKA dykes.
https://www.google.com/search?q=wire+cutting+pliers+dykes&client=firefox-b-1-d&tbm=isch&source=iu&ictx=1&fir=678f_GZDdfXm9M%253A%252CvHRe3VP9k6cj8M%252C%25 2Fm%252F06y28c&vet=1&usg=AI4_-kTq8p0ibRnl3si2ejbvZpfC4x8XIw&sa=X&ved=2ahUKEwiWl5eXqevoAhWBY80KHVs-A5AQ_B0wGXoECAQQAw#imgrc=678f_GZDdfXm9M:
Old 04-15-2020, 12:57 PM
E Sully's Avatar
Originally Posted by uwanna View Post
The problem with the floating plastic bits is they lodge in the recess that is cut in the shaft for the lock plunger to go into. When I had my problems, the wheel would lock till I jerked the wheel quite hard,
which I assumed caused the plastic bit to break up, freeing the the shaft. Does that sound like your problem? If so, you'll have to remove the tamper proof bolts that hold on the ignition lock unit then crawl under the dash and free up the lock unit. It's real tight quarters and a pain in the AZZ. Then I would bang on the steering tube to allow the bits to fall down the tube, but first I would remove all the leftover pieces of the bushing above from under the wheel. Anyway, that's what I did and it worked for me
YMMV! Good luck!
Something like this is why I would not push the sleeve down.
Ed
1973.5 T
Old 04-15-2020, 01:53 PM
Lots of good thoughts. I appreciate the feedback. I am not sure with as little space exists in between the shaft and the bearing that it can be gotten out - But I will try the suggestions and see. No need to give up yet.
"The problem with the floating plastic bits is they lodge in the recess that is cut in the shaft for the lock plunger to go into...... "
Thanks Ed. That is what I was wondering. Hard for me to know what is in the column waiting for FOD and putting me in the ditch.
Argh.........
Old 04-15-2020, 05:06 PM
Just brainstorming with you a bit... could you cut a strip of thin sheet metal, slide it between the homemade shim and the steering shaft, then take your wire welder and carefully see if you can spot weld them together? Then you’d have something to pull on to remove it.
I can think of interesting ways this could go terribly wrong! But it might work.
Good luck, we are rooting for you.
Old 04-15-2020, 05:19 PM
Looking at this pic from this thread " Steering shaft removal w/o removing column! " it seems the crappy sheet metal bushing might just fall down and ride on the lock catch casting.
I might have to try that if all y'alls ideas don't work to get it out. Worst case I pull the shaft and replace the bearing.
Old 04-15-2020, 05:39 PM
Pull the shaft and replace the bearing. It is not the end of the world.
Porsche 2005 GT3, 2006 997S with bore-scoring
Exotic: Ferrari F360F1 TDF, Ferrari 328 GTS
Disposable Car: BMW 530xiT, 2008 Mini Cooper S
Two-wheel art: Ducati 907IE, Ducati 851
Old 04-16-2020, 12:07 AM
Bill Douglas's Avatar
Thanks for explaining THAT. The only dykes I know would probably lose their temper and start smashing it with a hammer.
Old 04-16-2020, 12:15 AM
I like this idea. Especially if you could slide some thin copper on one, or better yet both sides of the offending shim.
81 Pacific Blue 930 Euro coupe slicktop on a strict diet, Rarlyl8 headers, Blowzilla turbo, Tial waste gate, Full bay I/C, Home made center out exhaust, Leask WUR, MSD 6AL, PLX wideband
Wevo shifter, LSD. Next up, Cams, Heads and port work
Old 04-16-2020, 12:23 AM
