Let's play - what's this tube?
Hi All, this is to the right in my engine bay on my -71 911T.
What is this tube for?
Thanks in advance,
Jörgen Forssling
Gothenburg
SWEDEN
Old 04-17-2020, 08:58 AM
Exhaust heat to air cleaner?
Old 04-17-2020, 10:43 AM
Rescuer of old cars
Arne2's Avatar
That's my guess as well. Moved to the other side for '72.
2018 718 Cayman 2.0
Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0
Old 04-17-2020, 11:08 AM
Thanks for your replies. It has no exit at the bottom. Looks like it makes a turn towards the heat tube. I think it is the circle on the drawing. If so, what is connected to it originally? And since I'm going to use aftermarket K&N type air filters should I just block it off?
//Jörgen
Old 04-17-2020, 01:59 PM
Senior Advisor
James Brown's Avatar
K&N? oh nooooooooo
08 Cayenne Turbo
Old 04-17-2020, 02:10 PM
Originally Posted by James Brown View Post
K&N? oh nooooooooo
Yes, that is the plan. The reason not is?
//J
Old 04-17-2020, 11:34 PM
Reiver
Reiver's Avatar
K&N allow more air...and more particulate matter (dust)...the two go hand in hand...every serious test shows that.
If you live in an area where you do not travel dirt roads or it is not dusty then fine.
I had one on my hotrod chevy some years back and so much dust got in the carb it jammed up the idle circuit. This was a factory oiled unit that was never re used...so....not over or under oiled.
De Oppresso Liber
Strength and Honor 5th Legion
Old 04-18-2020, 10:13 AM
Senior Advisor
yes same thing happened to me, on a v8 but when cleaning the filter, the carb was coated inside with fine powder like dust. the price you pay for high flow air. Racing, they're fine.
08 Cayenne Turbo
Old 04-18-2020, 10:16 AM
OK, so it's the filter, not the design of the air cleaner that is the problem?
And to my original question, do I block of this tube running this type of air cleaner?
//Jörgen
Old 04-18-2020, 01:45 PM
Senior Advisor
yes plug it up and you're fine.
08 Cayenne Turbo
Old 04-19-2020, 11:03 AM
Thanks! No dirt roads where I live. And certainly not for this car when the complete resto is done!
//Jörgen
Old 04-19-2020, 12:45 PM
Senior Advisor
Nice! keep us posted
08 Cayenne Turbo
Old 04-19-2020, 06:05 PM
