Tachometer and heat gauge not working on 1966
Was doing some work on the engine on my 66 and let it set for 15 years before I got back on it. Now it’s up and running but tachometer and heat gauge aren’t working. Noticed a broken wire from the heat sending unit , but din’t Know where to attach it on the relays on the firewall. Also din’t Know how the tachometer is wired. Can’t Find a wiring diagram that shows where it picks up the RPM’s. Vin number is 301733, probably built in June or July of 65.
Any help would be appreciated. Thanks, Gary Last edited by porsche66; 04-12-2020 at 02:13 PM.. |
Are you sure that's not a 1965? What is the paint code on your a-pillar?
66 temp. gauge
I have 66 and heat gauge wire goes into harness from front not relay. I run MSD so ca't help with tach. Will check wire color for gauge. Bob
Wide body kit, made a targa type top removable, reinforce the pan and undercarriage. Solex carbs, engine number is 901822. |
Gauges
Temperture gauge wire is green with black markings which are very hard to see. My wiring chart shows tach signal going to negative post on coil. Bob
Also, check the ground connections on the gauges. As I recall, some are in series to other gauges, so you might have one ground pin causing both to stop reading.
1973 911T Targa ROW |
Bought the 911 in 1977 with a lot of rust and news paper on the windows and primer with uns. Did some serious DIY modifications on it, most finished in 1985, a weekly driver for 20 years, moved and was in storage for 15 years. Put a new battery and new gas in last year and got it running and used it for our 50th anniversary wedding celebration and driv it in weekends now. I was young when I did all this and wanted a wide body Turbo, Targa or Cabriolet but couldn’t afford one so made 3 in1. Tops can be removed and bolted back. Reinforced the undercarriage and pan. Will try to attach pictures.
Sorry, you are correct about the color code. Couple more pictures after a finished it in the late 80’s. Drive it mostly as a Targa. Took about 30 mins and two men to get the top off. Me and about 10 mins to get Targa top off. Moved the battery to center of trunk a could the store the Targa top in the trunk.
Definitely a '65. I'm sure you are aware of the value of a '65 with a matching numbers engine and Solex's. That would be a costly one to put back to original but you might consider it. Any engine pictures?
Not sure what the value is “as is” but I know the envy and transaxle have value. Taking it back to original would be more than I would want to take on. Have seen clean 1965/66 911 for $80k -$250k . Attached picturesquely of engine. One back in mid 80’s the other today. I have the original breather. ![]()
