should there be a resistance across gauge elements ?
just for fun I thought I'd check this before installing.
I get a minor resistance on the TEMP gauge... about 150 ohms. the PRESS side appears open. this gauge is from a '71. is this normal ?
I have a similar gauge from '75 that behaves in the same way and another from '79 that gives a resistance on both elements.
input appreciated
Unclear on the concept ? Let's see if I can help.
1) You are NOT in the "fast lane" and...
2) You are NOT going "fast enough".
**News Flash**
You're in the Passing Lane. Any questions ?
Old 04-30-2020, 12:16 PM
Sent you a PM as well, but figured I'd post here also. Use your meter, set to ohms, and measure G to ground and G to 12V. You should have a resistance on both. However, the easiest way to test these gauges is to connect 12V and ground then use a little jumper wire connected to ground and touch it to the G terminal. When G is grounded the meter should be pegged all the way up.
1970 911E Sportomatic Albert Blue
1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI
1973 911E Glacier Blue
1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI
Old 04-30-2020, 08:03 PM
thanks again. greatly appreciated.
**News Flash**
Old 04-30-2020, 08:48 PM
