Easy hose to replace?
First off, sorry for the crappy picture. The car is at my mechanic so I can't get a better shot at the moment. There are two heater hoses, I marked their location in blue. This is on a 69 911e. The hoses pass through an opening right by the hood shocks, and I'm not sure how long they are, do they hook up with a clamp, where do they go to? The drivers side has a tear in it, so I would like to replace. Is this an easy fix? Thanks!!
Old 05-03-2020, 08:04 AM
heat from the engine.
Old 05-03-2020, 08:20 AM
Do these heater hoses that go up to the windshield come inside the car? I can't see where these hoses go to from the front trunk.
Old 05-04-2020, 05:28 AM
Pretty sure these connect to the heater pipes coming out of the rockers. You will have to remove the carpet that is on the outer kick panel in the foot well. Not sure how many variations they had on the heat ducting. I think none until they installed the kick panel fans
Old 05-04-2020, 06:31 AM
