Plug ID
Greetings:
Need help identifying this plug in the engine compartment, (the one with the red arrow). I need to replace whatever it is because its broken and the engine wont start if it is loose. If I'm not mistaken, the one in the middle and the lower one are from the crankshaft reference mark sensor. Any help will be appreciated. Thanks. 1986 PORSCHE 911 CARRERA TARGA 3.2
1986 Porsche 911 Carrera Targa 3.2 Lt H6
Old 09-09-2017, 03:56 PM
86 911 Targa's Avatar
Location: Manhattan Beach, California. Factory Delivery-Original owner-Retired engineer
Connector.
I think that may be your CHT harness connector.
You may have to replace the CHT sensor
with the attached harness/connector.
Part #930-606-915-00-M14
I did this on our 3.2.
Not sure why your car won't run?
Let me have a look around.
Gerry
pm me as needed.
1986 911 Targa.
Per Road and Track magazine:
Only in L.A.:
In the window of a bar in Hermosa Beach, California.
"Happy Hour prices during all car chases."
Old 09-09-2017, 04:10 PM
Ok thanks 86 911 Targa. You just refreshed my mind. I replaced the cylinder head temperature sensor a couple of years ago, but the electrical terminal housing that connects to it is broken. I did some research thanks to your input and found the terminal housing JUNIOR TIMER CONNECTOR-HSG part number A106202-ND from Digi-Key Electronics, and the rubber boot part number A105234-ND. Hope it fits like the factory housing. Will update.
Old 09-09-2017, 05:16 PM
Connector.
That will wok, and will save you the trouble
of replacing the sensor.
Best,
Gerry
1986 911 Targa.
Only in L.A.:
Old 09-09-2017, 06:06 PM
Connector does fit.
Old 05-02-2020, 12:59 PM
Maybe if the metal clip was still on it would work, 3 years ago.
206 637 4071
Old 05-02-2020, 02:41 PM
