Best deal for a 3.4 P&C?
I will be soon dropping my 3.2 Carrera engine to get it turbo'ed and lower its compression (its a PoW engine with high compression), and while I am at it, I thought I would get a 3.4 P&C, now I know these are not cheap but I thought maybe some one got them for a good price.
I will post a build thread soon to document my build, it will fun (and expensive!). |
Most cost effective way is to have your jugs bored, and buy new pistons. Talk to Jon at EBS in Reno. They will fix you up.
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Diss Member
For a "best deal" it still depends on what you think of as 'best". You can go for "cheap" but I think I'd go for more of a "long term reliability" solution.
I'd be inclined to pop the dollars for the LN Nickies as they should cool better and are stronger for a long life. Once you put the motor together you want it to have the longest life possible.
- "Speed kills! How fast do you want to go?" - anon. - "If More is better then Too Much is just right!!!" - Mad Mac Durgeloh -- Wayne - 87 Carrera coupe -> The pooch. |
Registered Minimalist
Research Bored jugs in the engine rebuild forum, some quality control issues coming up as of late. Reason I bring this up is because I myself am looking for 3.4 solutions. I'm leaning more toward a complete P&C kit, even though I have my mahle 3.2 jugs. I might just sell them to someone doing a 3.2 ss. motor instead of bore/replate.
Duane / IG: @duanewik / Youtube Channel: Wik's Garage Check out my 75 and 77 911S build threads |
I will go anywhere else to than to EBS after my experience with my failed conversion. BUT if you go there you MUST specify RA finish. 5-7 possibly. I believe new Mahles are just below 5. Consider instead using a well known engine builder. And forget about buying for lowest price. Can be very expensive
80SC (ex California) |
kamaro & 75 911s....I've PM'd you re: 3.4 P&Cs
regards, al
[B]Current projects: 69-911.5, Previous:73 911X (off to SanFrancisco/racing in Germany).77 911S (NY), 71E (France/Corsica), 66-912 ( France), 1970 914X (Wisconsin) 76 911S roller..off to Florida/Germany RGruppe #669 http://www.x-faktory.com/ |
