Question How to remove the doors?
Dear friends,
I have this 1982 911sc that I would like to remove the door, so the question is what´s the best method?
1-) remove the bolts from the hinge
2 remove the pin from the hinge
Also on the drivers door there´s 3 harnesses that goes inside the car, how do i disconected them?
Old 01-20-2016, 07:34 PM
SCadaddle's Avatar
If the door fits the car like it should right now, you'd be wise to remove the door by removing the hinge pins and not the hinges themselves as you could spend a LOT of time getting the door back on correctly screwing around with the up/down in/out of the hinges.
Old 01-20-2016, 07:58 PM
I found that it's really difficult to remove the hinge pins with the door on the car, without the pin tool from Porsche tool P 290 b.
Instead, I used an ATV jack to support the door, and just removed the 6 hinge bolts. Very easy. You must support the door while moving it away from the car so that you can disconnect the wire harnesses. One is inside the passenger compartment, one in the front trunk, and one inside the fenderwell area. They are very easy to disconnect. The hardest part of the job is to drive out the rollpin.
Old 01-20-2016, 08:00 PM
Ok, and is there any trick to do this job? Or just hammer it out?
Use a hardened steel punch of the exact right diameter. I used one from a set that I bought at Sears.
Old 01-20-2016, 08:02 PM
I just took a door of off my '70 and it wasn't easy. The top pin did not want to budge. If an '83 is similar you don't have a straight shot at it with a hammer and punch. If you mushroom the pin its never coming out. In the end I just marked the hinges and undid the bolts. I found the top pin was loose in the bushings so I had to remove it anyway. What worked really well was inserting a couple of 1/8" shims between the pin head and the hinge. There was a slight gap still in which I inserted an air hammer chisel. This worked very well. I wish I had taken a picture! I can get one if you are interested.
__________________________
'18 Macan S - my turbo Porsche
previous Pcars
'58 356A coupe, '00 Boxster S;'95 993 Polar Silver/Chestnut;'08 Cayman S;'70 911E
Old 01-20-2016, 08:31 PM
hello, Yes please
Old 01-20-2016, 08:52 PM
Discseven's Avatar
+1 on making fit. Question Ricardo... how's the fit now? If you're going to adjust anyway, might as well forget forcing pins out and remove bolts.
Originally Posted by SCadaddle View Post
...could spend a LOT of time getting the door back on correctly screwing around with the up/down in/out of the hinges.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 01-21-2016, 04:43 AM
Hello, the fitting is good, im removing the door to paint the car
Old 01-21-2016, 05:18 AM
911tracker85's Avatar
I am stripping my car to the tub for glass out repaint.
I removed the hinge bolts, but first gutted the door and pulled the wiring. at that point I could hold the door with one hand when I removed the last bolt.
good luck.
Bob Cox
78 930 clone project car.
87 924S resurrect at some point.
84 928S, Ruby Red linen/brown interior - sold
86 944 turbo my new DE/track car - sold
Old 01-21-2016, 05:47 AM
Apply some wd40 or similiar and try to remove pins first.
Old 01-21-2016, 06:01 AM
My pins popped right out of my 75... I was lucky (this time)...Tim
Old 01-21-2016, 07:27 AM
Here are a few pics showing how I got a stubborn pin to move. I hope my little recreation scene is adequate. The shims I had laying around. I probably got them from the generic do dad section at the local parts store years ago.
previous Pcars
Old 01-22-2016, 04:39 PM
Recently Disbanded
juanbenae's Avatar
I chose to remove the hinge from the jam, but traced it in sharpie prior to removal. with you painting this might not be doable and it appears you nailed it. I would plug the hinge holes prior to paint. any amount of paint getting in the pin races will create all kinds of grief.
Old 01-22-2016, 05:05 PM
I am restoring my 911SC and from everything I read I thought removing the door pins was going to be a big hassle. Many threads talk about the need for the special slide hammer tool which is expensive.
I made the tool in the picture using a piece of angle steel. It fits both top and bottom pins (you have to have the car lifted a bit to get the hammer under there for the bottom pin).
One or two hard hits with a 4lb engineer hammer and they each popped out. Boom. Easy.
Took longer to make the tool, and to tape around the area to protect the paint if the tool slipped, which it didn't.....
Old 02-03-2020, 07:51 AM
Harpo's Avatar
Looks good. Can we please get some dimensions on this tool?
Old 02-03-2020, 03:46 PM
1988 Carrera
shadowjack1's Avatar
I second that.
88' Carrera
79' SC gone (lost to Katrina)
75' Targa gone
72'914 gone
72' 914 gone too
Old 02-04-2020, 05:50 AM
A while back I had this tool made. You attach it to a metric threaded slide hammer. I also used a piece of pipe as a safety spacer so you don't hit the body. I would redesign it to bring the slide hammer farther away from the car body. However, being cautious it works fine.
Link: Door hinge pin removal tool
08 Aston Martin Vantage V-8 (6 spd manual) (DD)
20 Cayenne white-black/red (hers)
78 930 (heavily modified)
08 GT3 RS (white/black) (modified of course)
67 911S outlaw (sold)
Old 02-04-2020, 08:31 AM
One pin on both doors was frozen requiring the hinges to be unbolted. Once the doors were off the car a little heat help to get them off. I'll be replacing the bushings and pins when I reassemble.
Bill
1987 Marine Blue 911 Carrera Coupe RIP 01/2011
1987 Black 930 RUF Coupe Resurrected, 2488 lbs, EFI Technology, UMS Tuned - Mild & Wild, Current in pieces at paint
Old 04-19-2020, 10:25 AM
Originally Posted by shadowjack1 View Post
I second that.
Apologies for the very late reply on this. I missed your questions.
Its a 1"x1" angle iron. total length 11.5". length of the handle part (before it cuts to the narrow part) is 4"
Old 05-06-2020, 02:33 PM
