-   -   Why doesn't broken head stud destroy the engine within a few seconds ? (http://forums.pelicanparts.com/porsche-911-technical-forum/1060270-why-doesnt-broken-head-stud-destroy-engine-within-few-seconds.html)
sugarwood 05-08-2020 12:42 PM
I think people who rub their car with a diaper, drive it 200 miles a year, and mothball it 6 months a year since they only drive in 72F or warmer are more likely to suffer broken head studs. Sad !
juanbenae 05-08-2020 01:13 PM
^^^^ that shows just how informed you really are.
proporsche 05-08-2020 01:30 PM
http://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gifhttp://forums.pelicanparts.com/support/smileys/wat6.gif
Rawknees'Turbo 05-08-2020 02:06 PM
The lower/exhaust sides break because the dilivar alloy used was garbage (until the 993TT version) - plenty of instances reported where brand new ones broke upon assembly, which rules out corrosion being the only negative factor.
911pcars 05-09-2020 12:58 PM
The cylinders slide into spigots in the crankcase. 4 studs/cylinder, anchored in the case, snake through each cylinder and each cylinder head. The one-piece cam housing then clamps onto the three cylinder/cylinder head assemblies as one structural assembly. So no.
One or several head studs, even if simultaneously breaking, will not allow a cylinder to fall out or shift to any appreciable distance to implode the engine. This is not to say the engine cannot self-grenade. That requires other major component failure to occur. I’ll leave that scenario to your follow up question.
Sherwood
Bob Kontak 05-09-2020 02:05 PM
Maybe you could get a copy of Bruce Anderson's 911 Performance Handbook and read through it. It would be an investment in your credibility.
Seriously. It's old school. Pretty cool stuff and Anderson is a good writer.
Bob Kontak 05-09-2020 02:08 PM
Lion's share is pitting and axial shear post heat cycling.
Tell your Mom I said Hi.
Rawknees'Turbo 05-10-2020 12:58 PM
Agreed with that - amazing how weak and non-resilient those studs are (must be millennial "studs" :D).
You sister just gave my mom your message, bro! :)
