Brake adapter
Anyone know where I can buy the caliper adapters to use 964/c4 brakes retrofitted onto an older car?
See from your profile/pelican garage that you have a '77 930 -- most folks consider the 930's braking system to be the "gold standard" for vintage 911s --
what underlying braking issue are you trying to address/improve? Even stock SC/Carrera brakes should have more than adequate stopping power for agressive street driving out of the box and track-centric heat/fade issues can be addressed through proper pad selection and cooling mods. One issue that's been highlighted when brake retrofits have been previously discussed is the less than ideal front to rear bias that frequently result from these retrofits. |
best practice is to machining the mounting ears off and convert them to radial mount. Then use a caliper adaptor and 930 rotors stock 964 ![]() modified w/ hats to use 930 rotor annulus
I do have the 930 rotors/hats, c2 calipers. Just wanting to upgrade from the early 911 calipers. Went to get a caliper from the garage to post a pic but the wifes car is in my way. Ill et a pic tomorrow.
Appreciate the help Darren and Bil |
I recently installed 993 calipers. There is a great thread here called the ultimate brake upgrade with all the info you could ever need on brake upgrades. I recommend reading it before going any further
You need to be careful of the wheels because of brake clearance though the 993 or 964 rears are also easy as long as '78 up 930 rotors are used
cycling has-been
To directly answer your question -
VCI - Porsche 911- 930 69-89, 914/6 brake upgrade page Doug is the go-to guy for what you need. Bill K
73 911T MFI, 76 912E, 77 Turbo Carrera |
Above you can see a stock 964 front axial mount caliper here is one that I used on my own car a decade or so ago, you can see that the axila ears are shaved nd the body converted to radial mount w/ a caliper adapter, these would be used w/ '78-80 930 rotors w/ flat hats on 911 hubs ![]() In back you can do the same or fill the old axial mount holes and redrill as seen here to accommodate 930 rear rotors ![]() Just for comparison here are the current calipers on my car, from left to right 993RS axial mount rear stock, 993RS rear converted to radial mount w/ an adaptor, stock 993RS radial mount caliper. These all use 322mm 993RS rotors, 288 in back and 32mm in front
