My 3.6 won't idle and dies, idles and dies, repeat until Warm.
I know there are a lot of 3.6s installed across this thread.
My new to me 1992 C4 has gone through an extensive engine out re-fresh but it continues to stall at cold start, erratic idle, dies, repeats until warm and then drives great.
Initially the original ISV was cleaned, re-installed, but didn't resolve the issue.
I bought a new ISV (Lowe Automobil), installed it and it apparently "cured" the issue but it became re-infected. I didn't have the car at this time so I can't confirm how well it ran for or how long?
I have scoured the Forum, received some feedback and compiled the below list.
Any other suggestions? As mentioned, the car stalls at start-up and continues to stall out until warm. Please feel free to let me know if any of the below should be removed from consideration given that it eventually warms up, idles and drives normally.
1. O2 sensor?
2. ISV properly installed? Backwards?
3. DME relay
4. Engine Temperature Sensor
5. Vacuum leak?
6. Idle microswitch set-up / throttle linkage
7. Cylinder head temperature sensor
Thanks,
Chris
Old 03-27-2020, 07:51 AM
Had exactly the same symptoms you have. Read this post, it fixed my problem but
some weeks later problem resurfaced. Then repeated the fix, no problems since.
964 hard/no start problem
'80SC Widebody 3.6 transplant Anthracite "The Rocket"
Long gone but still miss them all:
'77 911 Targa, '72 BMW 3.0CS Coupe(finest car I ever had!)
'71 911T Coupe White, '70 911T Coupe Blue
'68 911 Coupe Orange, '68 911L Soft Window Targa
Old 03-27-2020, 09:11 AM
Continuing on the electrical side, a few years back my 964 started running erratically during warm up and stalling whether hot or cold. After a lot of testing and replacing ignition parts, I found that the main battery negative cable had approximately 700 ohms resistance instead of zero. A new battery ground cable solved all of the problems.
1990 964 Coupe
1986 Carrera 3.2 Targa
Old 03-27-2020, 09:56 AM
2 great suggestions. Thanks guys.
UWANNA, before you diagnosed and corrected the issue, did your car eventually warm-up and start to run properly?
I certainly will give this a go - can't see any downside to your proposed solution and it certainly is way cheaper than starting to order random parts.
Thanks,
Chris
Old 03-27-2020, 11:40 AM
Thanks,
Chris
Yes Chris, my symptoms were precisely the same as yours. Try the fix and good luck!
Grant
Old 03-27-2020, 01:01 PM
Chris,
Any update on your problem? Did you try my suggestions?
Old 04-14-2020, 09:16 AM
Thanks Uwanna.
The 964 is back in the shop. In addition to the cold start issue, there was a "dragging" sound from the steering wheel.
I'll definitely update this post if the issue is resolved with your suggested fix.
Thanks again.
Chris
Old 04-26-2020, 12:31 PM
So, we’re chunking through the list and still no resolution.
Uwanna, unfortunately your DME solution didn’t work.
Going to look for ground issues next.
Anyone else had a similar issue that was resolved with new ignition coils? Or a replacement DME relay? I want to try to avoid dart board new part purchases, if possible.
But, open to any/all suggestions.
Chris
Old 05-09-2020, 09:37 AM
