Alternator Wiring Question
Just purchased a new alternator and the wiring lugs are different than the existing alternator. I assume the wiring is the same as the original. Can somebody confirm?
Thanks ![]()
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD |
Vance.. it's hard to tell from the second picture but does your old alternator have an internal regulator? Do you have a picture of the old one after you removed it?
1970 911E Sportomatic Albert Blue 1971 911T Sunroof Coupe w/ Twin Plug 2.5 MFI 1973 911E Glacier Blue 1973 911E RSR Tribute Viper Green w/ 3.5 Twin Plug MFI |
I will post a pic when I get the chance. Thx
Alternator wiring connections.......
Vance,
Have you checked with the alternator supplier about the correct wiring connections. People who are not familiar with this alternator might inadvertently give you the incorrect information. I have the RED, BLUE, and BROWN wires for late SC’s alternators in my notebook when I removed them and installed back after the rebuild. But hesitant to offer them to you due the unidentified terminals of your alternator. Unless you find someone with an identical alternator, you are taking a big risk. Worse scenario, bring the alternator to someone who knows alternator like the back of his hand. BTW, some years ago, I bought an aluminum Trailex from Ohio and your name sounds familiar. Was that you? Thanks. Tony |
The upper right has a plus (B+), the lower left is battery light, and the lower right is the ground wire (-). You can use an ohmmeter to verify the plate polarities.
Dave Last edited by mysocal911; 05-10-2020 at 07:20 PM.. |
Here is a pic of my old alternator. Note how they are marked, whereas the new one has no markings. Teh new alternator is a Bosch alternator from our host, Part #: 911-603-120-HX-MI4
Vance '83 SC Cabriolet - The "Matrix" '73 914 - "Spicy Mustard" - SOLD Last edited by vesnyder; 05-11-2020 at 03:59 AM.. |
Here're the proper connections;
Dave |
Dave - Thanks. That is what I concluded after looking at the markings on both.
