1.367m later
KevinP73's Avatar
Send a message via Yahoo to KevinP73
Quick Targa window install trick
Installing a Targa back glass is not all that difficult. First I always remove the defogger harness from the car and install it on the glass before putting the seal (new) in place. Be sure to route the wires through the seal just like the factory does.
Once the seal is in place you slip the rope into the channel. I use a well waxed 3/16 cotton cord.
I use just plain soapy water in a squirt bottle to lube the seal.
With the cord in the channel, I slide the window into position in the window opening. Just like sliding your foot into a shoe, I position the leading edge of the glass so the seal engages the sheet metal flange being sure that the corners of the seal engage the flange.
This is the important part. I have anchor chains in my shop floor, using a couple inexpensive ratcheting tie downs ( bike straps) I'll drape the tie downs across the window and pull them down tight.
You don't need a lot of pressure, about 100 lbs. The window will handle a lot more than that so you don't need to worry about it breaking. Be sure that any hooks or the ratcheting device DON'T touch the glass.
Now I'll take my upholstry hook and engage the seal over the flange starting at the top leading edge and work all the way to the lower corners I don't pull the cord yet, I'm just using the upolstry hook.
Once the front edge is place, the sides of the seal should be within a 1/4 of the flange. By slapping the glass with an open palm you can "coax" the glass and seal closer into it's final position. Once the seal is close to the flange on the sides and the rear start pulling it into it's final position using the rope. Pulling about 2 or 3 inches at a time and slapping the window as I go. Slapping the glass not only makes your hand sore and bruised, but it helps seat the seal as you progress. It's not very likely that you will ever pull the entire perimeter of the window and have the seal engage the flange correctly. Slapping it as you go makes it a lot quicker in the long run.
Once the window is in then you reroute the defogger wires and install the Targa band cover and reassemble the interior.
Thats how I do it. 20 some years of practice definitly has it's advantages, but it's not rocket science.
non velox ad propitiare, verisimile non oblivisci
If it's not The Original Automotive Innovations and Restoration, then it's just hot AIR.
Old 06-10-2003, 10:37 AM
1.367m later
KevinP73's Avatar
One important detail I should mention. In the pictures of the strap placement the Targa band cover is already on the car. This is only because as I was doing this, I got too involved in actually installing the window and forgot to take pictures as I progressed. It was just one of those days !!
Old 06-10-2003, 10:43 AM
Thanks Kevin...Very informative and will make it's way onto my subscribed thread list.
Warren & Ron, may you rest in Peace.
Old 06-10-2003, 11:17 AM
that strap idea is the shiat!
206 637 4071
Old 06-10-2003, 11:34 AM
Heck, I’m only 5 not 71!
targa80's Avatar
Thanks for th info, What does the upholstry hook look like? Also I am assuming the rope is pulled from the inside to get the seal to seat on the flange?
Pat Henry
Targa80
1980SC Targa (Mocha Brown)
Old 06-10-2003, 12:06 PM
greglepore's Avatar
Yeah, baby! The slap part we had down, but the strap would have been a huge help.
Greg Lepore
85 Targa
05 ST3s (unfinished business)
Old 06-10-2003, 12:22 PM
Send a message via ICQ to old_skul
Locked
The requested resource is currently locked. The lock must be released or proper identification given before the method can be applied.
Kevin, fix your web page, please. I'd like to check it out sometime.
Got any tips for installing targa door seals?
Mark Szabo
1986 911 Targa 3.2 (I will miss you)
1985 Scirocco 8V (I will not miss you)
1986 Dodge B150 Ram Van (I can't believe I got $200 for you)
1987 Escort 5-speed 1.9 RIP
Old 06-10-2003, 12:41 PM
1.367m later
KevinP73's Avatar
Verizon accidentally "lost" it !! Tech support will look into it as soon as their nap time is over, or as soon as they hire someone who speaks english !!
Old 06-10-2003, 01:27 PM
Chuck Moreland's Avatar
Is the rope actualy put into the seal channel so that you draw it out once? or does it run perpendicular so you are working the rope around the glass?
Chuck Moreland - elephantracing.com - vonnen.com
Old 06-10-2003, 01:39 PM
1.367m later
KevinP73's Avatar
The rope is inserted into the channel that recieves the metal flange of the window opening. As you pull the rope it's supposed to lift the rubber edge of the seal and allow the seal to lap over the flange and hold the window in place.
Old 06-10-2003, 01:52 PM
Good pointer. When I did mine I wrapped two ropes in the channel. The Targa seal is difficult and it helps to have the second rope to pull in the event the first doesn't set the seal. I also made extensions for the defroster element. The wiring from the factory is very short and makes it difficult to connect before the window is intalled. By using extensions you can make the connection after installation.
Old 06-10-2003, 02:58 PM
1.367m later
KevinP73's Avatar
Door seals are the easiest. Is there a specific detail your asking about?
Old 06-10-2003, 03:36 PM
Kevin,
Great job, will show my window installer tomorrow.
Thanks again
Old 06-10-2003, 05:09 PM
Senior Member
Kevin,
Very good info!
Joe
Old 06-10-2003, 06:13 PM
Kevin,
How hard is the trim to put back on. Also somone had told me there is a targa seal that does not have the slot for the metal trim. Said It looks better than than the original seal.
Joe
Old 06-11-2003, 08:12 PM
1.367m later
KevinP73's Avatar
There is. I'm not sure of the part number though, it may be a 993 or a 996 number. I'll try to find it for you.
Old 06-12-2003, 09:16 AM
1.367m later
KevinP73's Avatar
Part number for the moulding-less seal is 964 545 052 40
Old 06-12-2003, 09:38 AM
limble's Avatar
I replaced the windshield (coupe) but we had trouble keeping it tight while pulling the cord. I used factory seals but have an unusual amount of wind noise.
Will a similar strap set-up work for installing the windshield on a coupe?
Maybe threading it through the car somehow so it stays normal to the windshield.
I'm going to give it a try unless someone says otherwise.
Thanks,
Mike
When I was a kid, I didn't want a stupid pony, I wanted a PORSCHE.
1970 911T Coupe, 1979 911SC Targa Euro, 1971 Honda CT70 HK Trail 70 (the ultimate in two wheeled transportation)
Old 06-12-2003, 10:44 AM
1.367m later
KevinP73's Avatar
Don't do it. The back glass is tempered, a windshield isn't. You'll crack the glass.
Old 06-12-2003, 11:11 AM
Great illustrations and instructions, Kevin. Thank you.
Would you, please, post a picture of your "upholstery hook?" I'm unsure what this means.
Thanks, again.
Old 06-12-2003, 12:28 PM
