-   -   3.6 originally automatic trans engine Engine to Manual? (http://forums.pelicanparts.com/porsche-911-technical-forum/1060801-3-6-originally-automatic-trans-engine-engine-manual.html)
0cean 05-11-2020 04:56 PM
This may be a stupid question, but is the 3.6 engine and CPU independent from the trans it has? Can you use a 3.6 engine from a auto car with a manual trans?
yahh 05-11-2020 05:29 PM
Yep, running a former sportomatic 3.6 with my 915 trans.
0cean 05-11-2020 05:51 PM
thanks
Jaskas 05-12-2020 11:06 PM
Same here former automatic 3.6 varioram with g50. Works fine!
ischmitz 05-13-2020 10:31 AM
The DME harness for a 3.6 has a coding plug that tells the DME whether it powers a manual or automatic transmission.
Bill Verburg 05-13-2020 02:39 PM
don't believe that to be true for 993, I'd need to look it up for 964
This I know, For 993 there is a 2 pin coding harness branched off from the DME wire harness near the control unit connector
There are 3 maps selectable
open - RoW
bridged w/ a 1kΩ plug, 944.612.492.00
grounded via a US only harness -US & Canada w/ SAI
The Tips have their own harness which codes the DME
The main difference other than coding between the m/t and tip harness is the lack of a reverse switching wire to activate the backup lights,
On the motor itself I seem to recall that there is a throttle switch not used on the m/t cars
All that said they can be used w/ some extra work, mostly to activate the reverse lights
0cean 06-24-2020 09:38 AM
Sorry for the late reply. Am I inviting a major pain by getting a 3.6 auto trans engine and matting it to a G50 trans? The reverse lights issue seams easy enough, yet ECU issues is way over my head. I have no formal mechanical training other then YouTube. :p
