3.6 originally automatic trans engine Engine to Manual?
This may be a stupid question, but is the 3.6 engine and CPU independent from the trans it has? Can you use a 3.6 engine from a auto car with a manual trans?
Yep, running a former sportomatic 3.6 with my 915 trans.
2024 GT4RS Ruby Star 2024 Raptor 2014 R8 V10 1982 911 3.6 Backdate |
thanks
Same here former automatic 3.6 varioram with g50. Works fine!
911-87 mit der 3.6 V-Ram und alles spaß |
The DME harness for a 3.6 has a coding plug that tells the DME whether it powers a manual or automatic transmission.
1974 Targa 3.6, 2001 C4 (sold), 2019 GT3RS, 2000 ML430 I repair/rebuild Bosch CDI Boxes and Porsche Motronic DMEs Porsche "Hammer" or Porsche PST2, PIWIS III - I can help!! How about a NoBadDays DualChip for 964 or '95 993 |
This I know, For 993 there is a 2 pin coding harness branched off from the DME wire harness near the control unit connector There are 3 maps selectable open - RoW bridged w/ a 1kΩ plug, 944.612.492.00 grounded via a US only harness -US & Canada w/ SAI The Tips have their own harness which codes the DME The main difference other than coding between the m/t and tip harness is the lack of a reverse switching wire to activate the backup lights, On the motor itself I seem to recall that there is a throttle switch not used on the m/t cars All that said they can be used w/ some extra work, mostly to activate the reverse lights
Sorry for the late reply. Am I inviting a major pain by getting a 3.6 auto trans engine and matting it to a G50 trans? The reverse lights issue seams easy enough, yet ECU issues is way over my head. I have no formal mechanical training other then YouTube.
