SPE SPE is offline
Turn Signal Will Not Cancel
I recently installed a MOMO steering wheel with hub adapter on my '82 911. I installed the factory slip ring and wired the horn button. The turn signal will automatically cancel for a left turn but not to the right. My thought was the slip ring may need to be re-indexed to move the position of the cancel arm. The problem is that the slip ring can only be mounted in one position on the hub to facilitate the pass-thru hole for the horn wire. What have I missed?
Regards,
Swen
Old 05-14-2020, 12:07 PM
slip ring
try position the ring at 9 o'clock...
Old 05-14-2020, 12:50 PM
