-   -   DIY: Fuchs RSR finish. (http://forums.pelicanparts.com/porsche-911-technical-forum/1061197-diy-fuchs-rsr-finish.html)
JackkTheMackk 05-15-2020 08:36 AM
While all my work is cancelled or postponed, I've been trying to stay busy in the garage and recently picked up some date matched weathered 15x7/8 Fuchs that were straight and true but looked a bit beat.
I had the wheels media blasted, then mounted them on the front of my 911 and used my motorcycle on the center stand and 2nd gear idle to spin them so I could wet sand the lips.
After the first wheel, with much respect and consideration for my last few remaining brain cells, I decided to engineer and fabricate an exhaust shield out of what I could find in the garage.
220 wet, 320 wet, 400 wet, and 500 wet sand for final lip polish. I did not want a mirror or glossy finish but enough to stand out from the barrel.
The next step was anodizing. I dropped them off at a local metal finishing place and had them clear anodized.
I taped off the stamping on the back of the petals to make sure no paint covers them and then in the openings of the petals. I taped off the barrels from excess paint running down also from the next step.
Slowly poured in Rustoleum satin black enamel paint till the level looked about right, totally eyeballed this one. Poked holes and let the paint drain after 3 minutes of sitting. let them cure overnight before removing tape and plastic from the backside.
http://forums.pelicanparts.com/uploa...1589558996.JPG
http://forums.pelicanparts.com/uploa...1589559643.jpg
http://forums.pelicanparts.com/uploa...1589559643.JPG
JackkTheMackk 05-15-2020 08:40 AM
I am wrapping them up and putting them in the attic until my whole suspension rebuild is refreshed so I do not have to readjust the ride height going from 16" to 15". Paint should be totally cured by then. Car is getting sport struts all around, 22/29 hollow bars, poly bronze bushings, and eibach sways. Plan for tires is 225/50 and 235/50 Toyo R888r.
Overall a really easy way to refinish them to factory anodized RSR spec without paying $500/wheel
http://forums.pelicanparts.com/uploa...1589560628.JPGhttp://forums.pelicanparts.com/uploa...1589560628.JPG
2jmotorsports 05-15-2020 09:09 AM
This is the most creative lathe Ive ever seen:
But o man the results!
http://forums.pelicanparts.com/uploa...1589562476.JPG
nene 05-15-2020 09:28 AM
Jesus, they turned out almost porn-like!
bkreigsr 05-15-2020 09:41 AM
Originally Posted by JackkTheMackk (Post 10866528)
......I taped off the stamping on the back of the petals to make sure no paint covers them and then in the openings of the petals. I taped off the barrels from excess paint running down also from the next step.
Slowly poured in Rustoleum satin black enamel paint till the level looked about right, totally eyeballed this one. Poked holes and let the paint drain after 3 minutes of sitting. let them cure overnight before removing tape and plastic from the backside....
Genius !!! http://forums.pelicanparts.com/support/smileys/clap.gifhttp://forums.pelicanparts.com/support/smileys/clap.gifhttp://forums.pelicanparts.com/support/smileys/clap.gif
4flyboy 05-15-2020 09:52 AM
Gorgeous
Uber Nice :cool:
jjeffries 05-15-2020 10:34 AM
Very cool.
How much did the anodizing cost? John
JackkTheMackk 05-15-2020 10:37 AM
Originally Posted by jjeffries (Post 10866687)
Very cool.
$100 for blasting, $200 for anodizing.
proporsche 05-15-2020 10:47 AM
very very nice job..i might copie your procedure when i do mine 7+8th /16 i just got;-)
excellent looking rim
Ivan
nene 05-15-2020 11:02 AM
:DI'd like to borrow the motorcycle please!!
Canada Kev 05-15-2020 11:06 AM
What material were they blasted with?
Looks like you got a great final result!
Rodney Nelson 05-15-2020 11:29 AM
That mortorcycle trick has got to be the most jerry-rigged/inventive thing I have ever seen on this forum.
The results speak for them selves.
Great job.
356911930 05-15-2020 12:09 PM
You will need to get the paint out of the lug nut recesses. This can lead to a loosening of the lug nuts if the paint chips out after installation.
Rahl
JackkTheMackk 05-15-2020 12:22 PM
Great job.
It ain’t stupid if it works
Rahl
Yes, on the list to do last. Waiting till the paint cures completely.
Blasted with a glass media at 75psi
Garen 05-15-2020 12:30 PM
Wow! they turned out great! And you managed to save yourself the tedious job of taping off the petals. Really cool.
75 911s 05-15-2020 01:30 PM
This is a dream. You are actually passed out next to your car with the bike still running.
Harpo 05-15-2020 01:56 PM
WOW love it
Anglocanadian 05-15-2020 02:49 PM
I'm impressed , would fit well in the "built not bought" category
RSBob 05-15-2020 06:28 PM
You could go into business - just an idea.
ian c2 05-15-2020 07:07 PM
Very nice .
When I was working in India , there was a Knife sharpening guy who used to visit all the local restaurants with a similar contraption , but made out of a bicycle :D
I once let him fcuk up my leatherman :rolleyes:
J-Gel 05-15-2020 07:13 PM
Wow love the contrast, nice work!
Oyagi 05-16-2020 05:40 AM
One of the best threads I’ve read here in a while. Love these pandemic DIY threads I’ve been reading all over the internet. That motorcycle lathe idea and exhaust shield is brilliant.
drcoastline 05-16-2020 06:13 AM
Great work and thank you for the information.
famoroso 05-16-2020 06:14 AM
Brilliant indeed!
Extra points for displaying the wheel on the grass. I cringe whenever I see pics of wheels on bare concrete (especially in for sale threads).
JackkTheMackk 05-16-2020 02:11 PM
took 10 minutes per wheel from 220-500. Was extremely quick.
Originally Posted by famoroso (Post 10867574)
Brilliant indeed!
I’ve been very careful with them after finishing them, don’t want to refurb them again lol.
GG Allin 05-19-2020 10:08 AM
Wheels turned out great.
I'm curious though, why not use the drive wheels of the car with the car jacked up, running, in gear instead of the motorcycle?
I suspect maybe you did this after the engine was pulled.
GG Allin 05-19-2020 10:16 AM
Oh, and did you thin out the paint at all?
Flojo 05-20-2020 05:49 AM
looks like a Pakistani how-to on YouTube :D
drcoastline 05-21-2020 02:17 AM
They came out great.
Which glass media? Glass bead, crushed glass and what grade? Sorry for the stupid questions.
Jonny042 06-21-2020 04:56 AM
My wheels have a 360 degree well between the petals and outer rim - using the pour methond on these will result in about 1/8" to 3/16" thick...... how did you deal with this?
GG Allin 09-10-2020 04:04 PM
Originally Posted by Jonny042 (Post 10915020)
My wheels have a 360 degree well between the petals and outer rim - using the pour method on these will result in about 1/8" to 3/16" thick...... how did you deal with this?
What he said.
$yncro 09-10-2020 08:27 PM
Great job! Any video link on pouring the paint to the wheel?
Was there any paint drip on the back side of the wheel when
You poked the holes?
You got it spot on. For the paint I assumed you poked a hole
in the rustoleum spray can.
Thanks.
