-   -   Vent window seal/ wind noise question (http://forums.pelicanparts.com/porsche-911-technical-forum/1061248-vent-window-seal-wind-noise-question.html)
ertech 05-15-2020 06:26 PM
Hi guys
Trying to figure out wind noise problem
Does Seal # 12 go on inside or outside of door
And should there bee scellant / butil between the side window frame and the outside and inside of door like picture circled in red.
http://forums.pelicanparts.com/uploa...1589592242.jpg
http://forums.pelicanparts.com/uploa...1589592302.jpg
Storage Man 05-16-2020 07:48 AM
https://youtu.be/V2mbNZ2uWGI
Not sure if this will help but it’s a good tutorial on the internal Mechnaicals on the door.
You might want to mention you cars MFG year in you post.
Discseven 05-16-2020 11:59 AM
ER... I've heard that the black plastic plugs that go in the door's front and rear need to be there or there's wind noise. I've not proven this true or false.
Otter74 05-16-2020 01:38 PM
I am pretty sure #12 goes on the outside but I will confirm when I see my car again.
HaroldMHedge 05-16-2020 09:59 PM
On my 87 item 12 is on the outside of the door.
Here's the TSB on Wind Noise and use of the plugs.
Originally Posted by HaroldMHedge (Post 10624579)
Porsche also issued a TSB 8802 Air Draft and Wind Noise in Door Area. This plug may help with your wind noise.
http://forums.pelicanparts.com/uploa...1571188844.png
Pelican has the needed part 111-971-911-A.
(There is a typo in their part number when I searched for the part.
