Vent window seal/ wind noise question
Hi guys
Trying to figure out wind noise problem
Does Seal # 12 go on inside or outside of door
And should there bee scellant / butil between the side window frame and the outside and inside of door like picture circled in red.
Old 05-15-2020, 06:26 PM
OCPO
Storage Man's Avatar
https://youtu.be/V2mbNZ2uWGI
Not sure if this will help but it’s a good tutorial on the internal Mechnaicals on the door.
You might want to mention you cars MFG year in you post.
2018 X5
86 911 Targa 3.2
80 Mercedes 450SL
2006 530xi BillyBoat/H&R's....gone
Old 05-16-2020, 07:48 AM
Discseven's Avatar
ER... I've heard that the black plastic plugs that go in the door's front and rear need to be there or there's wind noise. I've not proven this true or false.
Karl ~~~
Current: '80 Silver Targa w /'85 3.2. 964 cams, SSI, Dansk 2 in 1 out muf, custom fuel feed with spin on filter
Prior: '77 Copper 924. '73 Black 914. '74 White Carrera. '79 Silver, Black, Anthracite 930s.
Old 05-16-2020, 11:59 AM
I am pretty sure #12 goes on the outside but I will confirm when I see my car again.
'80 SC Targa
Avondale, Chicago, IL
Old 05-16-2020, 01:38 PM
On my 87 item 12 is on the outside of the door.
Here's the TSB on Wind Noise and use of the plugs.
Originally Posted by HaroldMHedge View Post
Porsche also issued a TSB 8802 Air Draft and Wind Noise in Door Area. This plug may help with your wind noise.
Pelican has the needed part 111-971-911-A.
(There is a typo in their part number when I searched for the part.
Old 05-16-2020, 09:59 PM
