-   -   Windshield Seal Install Question (http://forums.pelicanparts.com/porsche-911-technical-forum/1061758-windshield-seal-install-question.html)
arbita1 05-20-2020 05:40 PM
I had a shop replace my windshield. I noticed when I got home the top of the seal is not fully seated. You can see also the inside lip did not fully grab the inside. I feel like I could have someone press the top of the windshield while I pry out the lip on the inside. But maybe I’m wrong and it has to be removed and reset. If that’s the case it’s going back to the shop. I’m just trying to save myself the trip. Anyone have this issue?
http://forums.pelicanparts.com/uploa...1590021489.jpg
Marwil 05-20-2020 06:08 PM
You could use a plastic trim hook (not sharp) to pull while someone puts pressure from the outside. Start at the point where it is currently hooked over the body edge and work your way over. It may be easier to start at the side and work your way to the top also. How far over and down the side does it not seal? Don't apply to much pressure or you risk cracking it. I'm happily surprised it did not pop out on you on the way back home.
stormin48061 05-20-2020 06:11 PM
is the windshield oem or aftermarket? reason i am asking is because when i bought my car years ago, it had an aftermarket windshield. it was an abortion. the seal did not fit the because the windshield curvature was wrong, so the seal couldn't grab or seat properly. Whoever put it in tried to use urethane black sealant in the space in the curved corners of the windshield to seal the gap. It didn't work, when it rained, it leaked into the car. I had it replaced with a oem windshield and new seal.
arbita1 05-20-2020 06:21 PM
It’s probably about 12” in the center of the windshield. It’s only at the top.
arbita1 05-20-2020 06:22 PM
It’s the one from Sierra madre. I thought it was a sigla brand but I don’t see a label. So maybe it is aftermarket.
Marwil 05-20-2020 06:38 PM
You should be able to hook it over with some pressure from the outside. If it works great, if not the you'll have to have it redone.
Marwil 05-20-2020 06:45 PM
Home Depot - Hook and Pick Set by Milwaukee. Use the top right angle pick carefully. You could file the point to avoid damage. See image below.
http://forums.pelicanparts.com/uploa...1590025492.jpg
arbita1 05-20-2020 06:57 PM
I have a set like that and some plastic trim tools that may work too. I’ll give it a try.
Marwil 05-20-2020 07:13 PM
Let us know how it works out. Best of luck!
cabmandone 05-21-2020 03:14 AM
My advice for what it's worth,
Bring it back and tell the shop that installed it to fix it. The issue you have should be relatively easy to fix with, as you said, someone pushing down slightly on the outside while you slide a tool in behind the seal an then pull it along. If you're going to do it yourself, I'd spray it with some soapy water or even some windshield cleaner spray to help the tool slide and to help the seal slip past the metal lip and into place. But again, you paid for a proper installation. I'd let the company that did the install fix it.
I can't believe a pro would let that leave their shop with what in your picture appears like a gap between the seal and the outer frame. Nothing says "done by a pro" like a nice gap that leaks.
arbita1 05-21-2020 05:10 AM
It was kind of disappointing especially considering the cost. I emailed them this morning. The truth is if this is an easy fix I’d rather do it myself than go through the hassle of having to drop it off and pick it up again.
dg567 05-21-2020 06:12 AM
Who let the car leave the shop like that? Hope you don't go back for anything else.
Pedro '84 Coupe 05-21-2020 06:19 AM
Was the seal Porsche brand or aftermarket?
arbita1 05-21-2020 06:22 AM
Porsche seal.
Pedro '84 Coupe 05-21-2020 06:30 AM
Well there goes my theory haha. The shop should make it right then. Sometimes there is a gap in the corners that needs to be adjusted after install but I don't think I've seen a bad fit at the top like that with the Porsche seal.
Lyle O 05-21-2020 07:06 AM
Careful on what you attempt; if you screw up ANYTHING, your chances of getting the shop to address the issue appropriately go down considerably.
cabmandone 05-21-2020 07:07 AM
I know it will be a pain to bring it back in but don't let them off the hook man. Nothing burns me more than having to check over the work of a person that is supposed to be a professional in their field. Took a car to a detail shop the other day. Owner keeps asking me to look the car over and make sure it's satisfactory. I told him "You're the professional. I shouldn't be able to find anything that you haven't already addressed and if I do, I just won't bring the car back to you for the next detail"
People just don't seem to have the attention to detail that they should have. It's just "get it in and get it out" and that really burns me.
eastbay 05-21-2020 10:26 AM
The old maxim "if you want it done right, you've got to do it yourself" always applies. Bring it back, they will probably fLck something else up and deny it.
76FJ55 05-22-2020 08:24 AM
Post some pics of the seal where it seats along the bottom of the window. From my experience this area is much more problematic than the upper section. Because of the narrow space between the dash and the seal, it is much more difficult to evaluate this area since the interface between the seal lip and the body can't be seen directly. The seal itself should form a nice concave transition from the valance panel to the windshield glass. if it is convex at all it is a sign that it didn't seat correctly there either.
lvporschepilot 05-22-2020 08:29 AM
The aftermarket windshields are the issue. The seal in some areas only barely lips over the metal.
