Exhaust / Cat issue
Recently purchased a 1985 911 Cab with 46K. The issue in question :
1. I need to slip the clutch when starting out as the car has no power when pulling out in low gear. Once its underway the car pulls strong. 2. The exhaust sounds like it is blocked. When driving at a steady 3k RPM the exhaust note changes (louder) sounding like it was unplugged and then goes back to the more muted tone 3. I get a very random backfire once in a while between shifts (unspent fuel from a clogged converter?) I am leading to believe that the Catalytic Convert could be clogged or the Muffler has a baffle that has broken lose. Where do I start 1. Remove the convert and look for an obstruction 2. Replace the muffler 3. Install a tester pipe Any recommendations would be appreciated. Thanks, Ken |
I've seen multiple cat failures, the substrate will often fail mechanically, you usually hear rattling but it depends on the failure mode
Thanks for the reply, will do and post a reply
If the cat is obstructed, do I replace it with another cat or bypass ?
![]() More specifically, You'd need to replace it with a cat if your car needs to be smog-legal/smog tested. If you don't NEED/want to be smog legal, you can replace it with a pipe or european pre-muffler OR can hollow out the cat to remove the obstruction and make it into a pipe. I'm very happy with the active cat exhaust I purchased from M&K - check out the bottom of this page https://mkexhaust.com/911-2/ for options |
San Diego, CA
If you install a cat bypass the exhaust note will be a little louder.
...and the car will run a lot better!
'87 Carrera (3.4L) w/Turbo, full-bay IC; front bumper aux oil cooler, etc. '07 Boxter |
Flat Six
Ken, where are you located?
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
Thanks for the advise..... Leaning toward a cat bypass.
Flat Six, i am located east of Pittsburgh PA. |
It will also get rid of a lot of weight and heat in the engine bay/bumper/deck.
2018 Porsche 911 GT3 manual 1984 Porsche 911 Carrera Targa 2021 Porsche Macan GTS 2018 BMW R1200GS Adventure Rallye 2020 Ducati Scrambler 1100 Sport Pro |
Rescuer of old cars
I noticed no power difference in my previous '84 between the catalyst and a pre-muffler. No difference in sound either.
But a huge difference in smells. With the catalyst removed the exhaust stink was bad, smelled the garage up something horrible. Probably has something to do with the chemical stew we have these days instead of real gas. But in any case, the catalyst cleared that all up, no more smelly garage.
2018 718 Cayman 2.0 Priors - '72 911T coupe, '84 911 Carrera coupe, '84 944, '73 914 2.0 |
Interesting, second time in a month I've read a "no cat the exhaust stinks" comment. Just as an observation if you consider removing the cat; I had a "cat" on the 3.2 in my car and in the 5 yrs or so I've owned it never noticed the exhaust as WOW that stinks. I recently discovered the "cat" was nothing more than a hollowed out fat pipe. Exhaust has not smelled "bad". I wonder if related to brand/grade of fuel?
74 911 3.2 |
Clogged catalytic converter?
This thread has a few informative suggestions on how to confirm/rule out a clogged cat, including a) measuring its temp (after engine's warmed up) at the front and back -- if front significantly hotter than back, good sign cat's clogged or b) drilling a hole into the very front part of the cat and measuring the level of back pressure with the engine running (problem if over 5psi) and then sealing the hole with a screw if the Cat's OK |
Flat Six
I have an extra, low-mile cat I'd loan to you if you were in the Las Vegas area . . . .
That’s strange. When I first installed my cat bypass I had that smell for the first few weeks but it has gradually diminished to no smell at all after a few months. I assume this is from heat cycling and better sealing. I’m very sensitive to smell and nothing now.
Thanks for the clarification Darrin.
Rescuer of old cars
